Old 04-19-2012, 01:08 PM #1
blackmax's Avatar
blackmax blackmax is offline
blackmax is on a distinguished road
blackmax's Avatar
How much grease in drive-shaft zerk fittings?
Just crawled under my truck yesterday to grease the drive shaft fittings. Some took just a pump or two before grease came squirting out of the seals....like normal. But there were 2 or 3 where I pumped maybe 20+ times.....and the grease just kept going somewhere??? Where was it going? Can you overfill.....probably not possible and just make a mess if you do, but I'm a little confused as to how much grease to put into the fittings where it doesn't become obvious that they are full. ??
blackmax is offline   Reply With QuoteReply With Quote
Old 04-19-2012, 07:07 PM #2
Gatafly Gatafly is offline
Gatafly is on a distinguished road
When I first did mine it took 60 pumps until the slip joint moved. You want to keep .an eye on it while you are pumping and as soon as it expands you are done
Gatafly is offline   Reply With QuoteReply With Quote
Are there any other grease fittings on 4th gen Carl_G 4th Gen T4Rs 15 02-26-2020 08:14 PM
zerk fittings on driveshaft - 08 SportEdition? irish44j 4th Gen T4Rs 8 06-29-2011 10:41 AM
03 Zerk Fittings moreland01 Maintenance/Detailing 2 12-02-2008 07:10 PM
Is this the correct grease for drive shaft? msanta Problems & Warranty Issues 15 02-15-2005 11:51 AM
