Originally Posted by oljedi11950
Quick ? do the sensors have to be reset as far as ecu , thought I saw someone had problems any issue's at all as far as different wheels or should switch out sensors thanks
I would switch the sensors out unless you have a TPMS capable scantool that will do Toyota TPMS.
If you don't swap them out, you'll need to reprogram.
