Old 04-26-2012, 06:22 PM #1
Nealf2002 Nealf2002 is offline
Nealf2002 is on a distinguished road
Help dead battery and can't open doors...
Hi my in laws have gotten into a jam where they can't open any door with the key and a dead battery on a 2003 4runner. Any ideas what I can do? The dealer says they have never heard of this...
Thanks.
Nealf2002 is offline   Reply With QuoteReply With Quote
Old 04-26-2012, 06:50 PM #2
Druss's Avatar
Druss Druss is offline
Druss is on a distinguished road
Druss's Avatar
Thanks.
Sorry about your problem ...have they tried every door or just one? I would
think using the key in a mechanical lock should work on one of the five doors.
My car door won't unlock? - Yahoo! Answers
Druss is offline   Reply With QuoteReply With Quote
Old 04-26-2012, 07:09 PM #3
Follow up
Yes they claim they have tried both doors, and the rear hatch... We are all stumped here... Thanks for any help in advance...
Old 04-26-2012, 08:24 PM #4
Zuke's Avatar
Zuke Zuke is offline
Zuke is on a distinguished road
Zuke's Avatar
Are they using the master black key?
03 Toyota 4Runner 4x4 V8
96 Toyota T100 4x4 150k miles (traded)
97 Toyota Corolla CE 167k miles (totaled)
94 Toyota p/u 4x4 150k miles (traded)
87 Toyota p/u 270k miles (sold)
Zuke is offline   Reply With QuoteReply With Quote
Old 04-26-2012, 10:41 PM #5
DC runner DC runner is offline
DC runner is on a distinguished road
They need to jiggle it...
This could quite possibly be the first time that physical key gimble has ever been used and if so, it is probably stubborn. Assure them that their key will open the door and a squirt of wd40 might help.
DC runner is offline   Reply With QuoteReply With Quote
Old 04-26-2012, 11:26 PM #6
J053619 J053619 is offline
Real Name: Jose
J053619 is on a distinguished road
Real Name: Jose
Haha I actually just helped my boss today open his X5's tailgate because his battery was dead. As for the 4runner with all doors locked not sure how to help on that :\
J053619 is offline   Reply With QuoteReply With Quote
Old 04-27-2012, 11:27 AM #7
nyc4runnin's Avatar
nyc4runnin nyc4runnin is offline
nyc4runnin is on a distinguished road
nyc4runnin's Avatar
if the battery is dead, the master key will work in the driver door only. if it doesn't work, then there's something wrong with the key/lock.
nyc4runnin is offline   Reply With QuoteReply With Quote
Old 04-27-2012, 11:30 AM #8
nyc4runnin's Avatar
nyc4runnin's Avatar
if you're daring enuf, u can also remove the license plate light, and inject your own 12VDC source into the lamp socket - should be enuf to power up the automatic locks. make sure u know which wire is ground !!!! LOL
Old 04-27-2012, 11:39 AM #9
Sungod Sungod is offline
Sungod is on a distinguished road
As nyc said, the only door you can open with a key is the drivers door. No other doors are key locked. The rear hatch requires voltage. Check around to find out which window is the least expensive and compare that to the price of getting a lock smith out to get in.
Sungod is offline   Reply With QuoteReply With Quote
Old 04-27-2012, 02:24 PM #10
Asmara Asmara is offline
Asmara is on a distinguished road
I'd probably see if you can access the hood release cable, cut that and then pull the center wire. Probably cheaper and easier to fix. Once you get the hood open, you can put power to the battery and use the remote. Looks like the cable runs about $25.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods: Spoiler, HIR bulbs, Kenwood DNX6960 Nav, Back Window Up with Remote Mod, Rear Camera, LED Tails, Key Reminder Disable, OEM Automatic Headlights, Rear USB Ports, Seat Heaters, Aftermarket Third Row, Heated Side View Mirror
Locations: VA
Asmara is offline   Reply With QuoteReply With Quote
Old 04-27-2012, 02:33 PM #11
I mean, if they ever started the dang car they have the right keys. It has to be the key lock mechanism is stuck from non-use and they should be able to jiggle it and wd40 it open.
Old 04-27-2012, 05:30 PM #12
Druss's Avatar
Druss's Avatar
Thumbs up
Wow these modern vehicles are so technology enhanced!
Old 04-27-2012, 05:58 PM #13
It sounds simple, but have you used your key in your lock recently? Possibly 9 years of road salt and grime could be built up in there. That might be a little more than some spray lubricant can handle. I think I might go try mine just out of curiosity because now that I think of it, I don't think I have ever used my key in the door. I only use it in that rear hatch.
Old 04-27-2012, 06:05 PM #14
Getting to that cable would be a challenge. It runs along the fender and then next to the radiator support. You can see it from the space in between the bumper and the radiator, but the section that is exposed runs in side a metal tube. It could be done, but personally I don't have the patience. A brick would be quicker.
Old 04-27-2012, 07:20 PM #15
Gecko123 Gecko123 is offline
Gecko123 is on a distinguished road
Thanks.
call AAA and get them to use a slim jim. don't break the windows. you want the original windows. having a replacement window is just not the same as they may not do a good job with the seals and the window itself may not be the same quality as the original
Gecko123 is offline   Reply With QuoteReply With Quote
both doors locks but wont open by switch Arnie19 Classic T4Rs 0 03-11-2011 04:55 PM
Rear doors won't open Merle Problems & Warranty Issues 0 11-27-2010 10:45 PM
Dead Battery ron70062 3rd gen T4Rs 6 08-26-2008 03:29 AM
03 Dead Battery?? impulsebrklyn Maintenance/Detailing 4 06-14-2005 11:49 AM
Map Lights On When Doors Open pbm317 4th Gen T4Rs 11 08-11-2004 02:12 PM
