06-21-2005, 10:51 AM
Smaller Spare Tire?
Has anyone upsized their tires from 65/17 to 70/17 (4th gen) and left the spare 65? If so, has anyone had to use the smaller spare and experienced any problems (with traction or stability control, etc.)?
Koz
06-21-2005, 11:14 AM
Re: Smaller Spare Tire?
it's probably a very bad idea to not upsize the spare at the same time - given the sophisticated drivetrain.
06-21-2005, 11:56 AM
I think it's should be ok as far as you use it as spare tire. If you not going to drive too fast (max. 80km/h or 50mph) and will drive to nearest tire center. Most passenger cars has small spare tire and it works well. From another point of view, if you going to use it as primary tire - no, you should get the same size as main 4 tires.
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
06-21-2005, 01:51 PM
The smaller cars with the donut spares are ok because they don't have 4wd.
You COULD get away with it by lowering the pressure of the opposite side or all 3 but I think the difference is small enough to get away with it. I wouldn't drive it very far like that but it should be ok in a pinch.
-Bobby
'10 Ford F150 FX4
'04 Sport Edition 4wd V8 Stratosphere Mica (sold)
'04 KTM 950 Adventure - '08 KTM 450 EXC
06-21-2005, 02:02 PM
Haven't tried it, but IIRC, the owner's manual warns that different-sized tires screws up the ABS wheel speed sensors...
[SIZE=1]
On Matters of Most Grave Concern
06-21-2005, 02:09 PM
They program in a margin of error. If you go slow enough (under 65mph) you should be ok. If you deflate the other tires, you should go much slower.
Koz - stop being a cheapass and spring for the 5th tire
-Bobby
'10 Ford F150 FX4
06-21-2005, 03:09 PM
This came up in another tread. I just have a need to know. I will be replacing my stock tires (when the time comes) with the stock size (Revos of course). I will be on pavement 98% of the time. I want the wider stock size. A half inch taller is not going to make a difference for the driving I do.
Koz
06-21-2005, 04:54 PM
I'd recommend not exceed 50mph limit
06-21-2005, 05:34 PM
So THIS is why the manual recommends to include the spare tire on tire rotation.
2005 Japanese export version Toyota 4Runner Limited.
3.0L Intercooled Turbo Diesel engine.
Original Toyota 4Runner All-weather floor mats.
Original 4Runner Cargo Liner.
PIAA 90 Pro XT Driving/Fog Auxiliary lamps.
V-Kool spectrally selective window film: 70% Transparency Windshield (V-70), 28% (K-28) Windows / Sunroof.
Draw-Tite Round Tube Max-Frame hitch receiver.
Xetronic H.I.D. system on Low Beams.
PIAA Xtreme White Plus 9005 bulbs on High Beams.
Hella Optilux Xenon White 9006 bulbs on Fog Lamps.
3M Filtrette Air Conditioner Filter Mod
06-21-2005, 05:45 PM
Offroader, what the mod do you have: "DrawTite Round Tube Max-Frame hitch receiver"? How it looks like? Do you have any images?
06-22-2005, 07:39 AM
It looks like this:
You can find out more at:
http://www.draw-tite.com/products/pr..._class34.shtml
I purchased mine at:
http://www.drawtite.com
06-22-2005, 07:46 AM
The stock V8 hitch looks the same, round tube and all. It may even be better.
Koz
06-22-2005, 03:43 PM
Koz
Yep, but my japanese version 4Runner didn't include a receiver, so I had to purchase an aftermarket one.
06-22-2005, 06:03 PM
I have mine as OEM. Looks like all North American 4Runners comes with OEM hitch.
