Old 05-03-2012, 12:47 PM #1
exclusivebeef's Avatar
exclusivebeef exclusivebeef is offline
exclusivebeef is an unknown quantity at this point
Hella 500 Install Issues
I am installing Hella 500s with a switch on my 2007 4Runner. I've never had issues doing this in the past. I have the relay, switch, and lights wired properly. I was using the bulb connection for the headlight as a temporary remote power source just to make sure everything would work. I have not blown any fuses. The only thing that I am doing that I could see as an issue is my ground wires. I have my Hellas, switch, and relay, all grounded to the negative battery terminal ground on the frame. Are there any other issues that I could be missing? The small LED even comes on on the switch, but there is no light from the Hellas. I have plenty sufficient wire as well. Thank you in advance.
2007 4Runner SR5. Black Weathertech floor mats installed. 2.75/1.5 cornfed installed. (255/75/17) mud terrain mounted on 17" FJ wheels installed. 50w H.I.D. conversion
exclusivebeef is offline   Reply With QuoteReply With Quote
Old 05-03-2012, 01:12 PM #2
4Rida 4Rida is offline
4Rida is on a distinguished road
What about the positive connections? Are they connected to the battery as well?
(assuming you're only using the headlight connection for input to the relay)
'06 4.7l Limited
'16 Sr5 Premium
4Rida is offline   Reply With QuoteReply With Quote
Old 05-03-2012, 01:17 PM #3
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
If you have it wired to your headlamps that may be the problem.
Most things on the 4runner are actuated by completing the ground instead of the positive.. Kinda backwards.
I know the interior lights are that way and I believe the headlights are too.
I think most people who want the aux lights on with highs have to wire in an extra relay to actuate the positive on the aux lights when the negative on the headlights is completed. If you search around you should be able to find a better answer.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 05-03-2012, 02:03 PM #4
The lead from the lights is connected to the relay and the relay is connected to the battery via 87 and 30 respectively. I also tried using the cigarette lighter as a remote power supply. That did not work either. Can you blow a relay? Is there a chance with the trial and error, or error in my case, that I have blown my relay?
Old 05-03-2012, 02:06 PM #5
Originally Posted by exclusivebeef View Post
No, my lights are not connected directly to my battery. I am using a relay and switch. I also tried using the cigarette lighter as a remote power supply. That did not work either. Can you blow a relay? Is there a chance with the trial and error, or error in my case, that I have blown my relay?
Can you hear the relay click when you send power to it? Try bypassing the relay by connecting 87 and 30.
'06 4.7l Limited
'16 Sr5 Premium
Old 05-04-2012, 02:32 PM #6
I bypassed the relay and connected 87 and 30. Let there be light. I still cannot figure why it is not working with the relay. Relay is grounded. Switch is grounded. The LED on the switch is coming on. I've tried connecting the switch to the cigarette lighter and to the headlamps. No luck.
Old 05-04-2012, 02:53 PM #7
T4runner13's Avatar
T4runner13 T4runner13 is offline
T4runner13 is on a distinguished road
T4runner13's Avatar
A multimeter would help?
2006 Sport v6|OME 885's with 90000 Front OME 895 with 60004 Rear|Front Diff Drop|LR UCR|BFG AT 285/70/17 on XD Addict|PIAA 520 ATP|PIAA 520 Pencil back loaded behind Custom Satoshi Grill|Hella backup lights|HID Conversion|Blacked out Headlights|Weathertech fitted mats|Weathertech Deflectors|Gibson exhaust turned behind tire|Stubbs HD-SKO|TRD CAI|aFe TB Spacer|Ultra Gauge|Optima Yellow Top|ARB High Output On-Board Air|Interior LED Swap|Sway Bar relocate and Poly bushings|De-bagged|Black Toyota symbols|Hi Lift Xtreme 60|Recovery Gear|Receiver Hitch D-Ring with Shackle|BAMF LCR Skids| Pioneer AVH-P3100
T4runner13 is offline   Reply With QuoteReply With Quote
Old 05-04-2012, 03:27 PM #8
Sounds like you have a bad relay. Did you place a fuse anywhere that could be blown?
Double check your connections on the relay - maybe reverse 85 and 86.
'06 4.7l Limited
'16 Sr5 Premium
Old 07-28-2014, 08:06 PM #9
HoffPSH13 HoffPSH13 is offline
HoffPSH13 is on a distinguished road
Did you ever fix the relay, if so, where did you get a new one?
HoffPSH13 is offline   Reply With QuoteReply With Quote
auxiliary , ground , hella , issue , lights
the 3rd hella install in as many days, lol theizzardking 3rd gen T4Rs 11 11-19-2013 09:18 AM
Hella BlackMagic 500's install T?@\7 Classic T4Rs 15 07-27-2011 01:33 AM
Hella 500 install question jeeper1 3rd gen T4Rs 21 05-24-2011 12:55 PM
Need Help on Hella 500 install Beaston Engines / Suspension / Wheels / Tires / Audio / Accessories 14 04-27-2007 04:10 PM
hella 500 install irwinSR5 4th Gen T4Rs 7 03-20-2007 05:31 PM
