Originally Posted by exclusivebeef
I bypassed the relay and connected 87 and 30. Let there be light. I still cannot figure why it is not working with the relay. Relay is grounded. Switch is grounded. The LED on the switch is coming on. I've tried connecting the switch to the cigarette lighter and to the headlamps. No luck.
Sounds like you have a bad relay. Did you place a fuse anywhere that could be blown?
Double check your connections on the relay - maybe reverse 85 and 86.
