Old 05-07-2012, 11:09 AM #1
Aquabear's Avatar
Aquabear Aquabear is offline
Aquabear is on a distinguished road
Aquabear's Avatar
Body Mount chop vs LR UCA
Will installing Light Racing UCA's help avoid doing the Body mount chop?
I have a small rub 1-5% of the time on the body mount, I looked and saw a tiny rub area on the body mount 1/4 inch area. I am guessing it rubs only on fast or hard -hard bumps offroading or NASCAR driving in NYC- which are almost the same due to potholes haha. If you guys want I can take a pic.
I can cut the metal but can't-well not yet -weld so I'd have to pay- sucks but I do have a great custom truck shop here.
Since it's a very small area, should I not worry about it? 99% of my driving is on road, 10% beach on long island and maybe once every other month will I offroad at rausch creek or something.
Also, in a week I will be installing a 1.5 inch spacer lift in the rear and then raise front height about .5 inch now will this said clearance be good enough to not need either the LR UCA or BM chop?
thanks in advance
2016 T4R Trail - Rogue
Nitto TG2 285/70/17, Toytec Ultimate Lift, AFE CAI, Borla CAT BACK, URD MAF Cal, Sprint Booster
Pepe 2008 T4R V6
Aquabear is offline   Reply With QuoteReply With Quote
Old 05-07-2012, 11:32 AM #2
zimm zimm is offline
zimm is on a distinguished road
Nope. I have light racing UPRs, same tires and had to chop the mount severely, and even hammer the pinch weld behind the fender liner to make room.
2008- sold
zimm is offline   Reply With QuoteReply With Quote
Old 05-07-2012, 11:34 AM #3
aha2988's Avatar
aha2988 aha2988 is offline
Real Name: Austin
aha2988 will become famous soon enough aha2988 will become famous soon enough
aha2988's Avatar
Real Name: Austin
LR UCA's only aloud me to get my caster back to factory and a bit more camber adjustment which i highly recommend def improved the ride and handling. (and somehow gave me the peace of mind that i could baja race if i wanted lol) not that i baja race haha. I had rubbing in my front bumper, rear of front fender, and body mount (minal like you said) i trimmed the front bumper slightly, and trimed a small amount of the rear of the front fender and still rub the body mount slightly haven't had any issue's on or off road, just recently put a body lift on 1.25" which made me regret trimming lol cause the body lift would've taken away the fender rubbing. I'm still planning on the body mount chop, I think guys running body lifts and spidertrax wheel spacers are getting away with no rubbing without the body mount chop, with 33's; you can go to 35's with the wheel spacer set up + body lift+body mount chop. I would think though it would cost more to get the spacers than to chop the body mount in your case. but you would need the body lift with the spacers or you'll deal with fender rubbing to. some guys might disagree with me having experience with different set ups but this would be my .02 cents (BTW: with my aftermarket rims I have about a 3/4" center tire offset and i have a 1/4" wheel spacer up front to get my rims to clear the face of the break caliper and i'm running a 12" wide tire hope this helps)
-Austin
A-Ha's Build
aha2988 is offline   Reply With QuoteReply With Quote
Old 05-07-2012, 12:24 PM #4
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
Wheel spacers increase rubbing, they definitely won't help rubbing (except on the uca). I think you may be able to get around the chop with new ucas. As you increase caster, this pulls the wheel further forw. With the added caster adjustment from ucas, you may be able to get it pulled forward enough to avoid the chop.
I've got 3.5" suspension lift, .5" body lift "which didn't affect body mount rubbing), Light Racing ucas, spidertrax, and 285 duratracs. So far, I've noticed no rubbing on the body mount. I don't know exactly where caster is set, but I told the shop to set it as high as possible while keeping other numbers in spec.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 05-07-2012, 12:58 PM #5
jdkilroy's Avatar
jdkilroy jdkilroy is offline
Real Name: Jon
jdkilroy is on a distinguished road
jdkilroy's Avatar
Real Name: Jon
what is the benefit of caster that is greater than OEM spec ?
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
jdkilroy is offline   Reply With QuoteReply With Quote
Old 05-07-2012, 01:15 PM #6
aha2988's Avatar
Real Name: Austin
aha2988's Avatar
Real Name: Austin
it tightens up your steering at higher speeds. for instance drag cars rock there steering knuckles back almost to 45degrees so the tire wants to stay straight more so than it wants to turn. just a drivers preference
-Austin
A-Ha's Build
Old 05-08-2012, 10:21 PM #7
Aquabear's Avatar
Aquabear's Avatar
Thanks aha and Ark for all the input. Later this summer I'll add in the LR UCA to avoid body chop. I am TOTALLY digging the fact of better steering response!!! My 4R response is not as great since the lift and bigger tires.
Pepe 2008 T4R V6
Old 05-09-2012, 08:04 AM #8
Sure thing. I wouldn't rule out the chop as there's no guarantee that the ucas will get rid of all the rubbing. It really depends on where your caster numbers are currently.
Edit: here's a good thread on the topic. It's for the FJ but also applies to the 4runner.
http://www.fjcruiserforums.com/forum...hout-chop.html
Old 05-09-2012, 11:59 AM #9
Aquabear's Avatar
Aquabear's Avatar
ASR WOW just read what the link brought me too. I was about to ask a question to you but after reading all my answers are there! This is huge man thanks!!!
Pepe 2008 T4R V6
Old 05-09-2012, 12:06 PM #10
aha2988's Avatar
Real Name: Austin
aha2988's Avatar
Real Name: Austin
Get rid of the RUB without a CHOP - Toyota FJ Cruiser Forum
yeah that def explains why my front left is rubbing the body mount at full crush/turn and my passanger side doesn't rub at all thanks ASR!!
-Austin
A-Ha's Build
Old 10-22-2014, 09:56 PM #11
ARunner's Avatar
ARunner ARunner is offline
Real Name: Kyle
ARunner is on a distinguished road
ARunner's Avatar
Real Name: Kyle
What are you guys able to manage as far as a caster number with the SPC/LR UCAs? Are the shops setting your UCA to the max caster setting or is a lower setting required to maintain proper toe and camber? Heading to alignment shop tomorrow because with Toyota standard alignment I am getting rub when turning with minimum (sloped parking lot) flex.
03 Limited V8 4WD
ARunner is offline   Reply With QuoteReply With Quote
Old 10-23-2014, 12:09 AM #12
Jeremy556's Avatar
Jeremy556's Avatar
Someone that knows what they are doing (maybe 5-10% of alignment techs) should be able to get >6 degrees of caster with everything else in spec with LR UCAs. The sliding upper ball joint makes it stupid simple and easy to dial in camber.
With TC UCAs, I have 5.5 degrees of caster. Slightly more negative camber than I would prefer, but still within spec.
Old 10-23-2014, 09:10 AM #13
ARunner's Avatar
Real Name: Kyle
ARunner's Avatar
Real Name: Kyle
Good to know. When Toyota changed my alignment after I installed my lift and charged me extra due to the "difficulty" added from having an adjustable UCA (despite making it clear when I dropped it off) yet when I got it back the UCA adjustment was just as I left it when I installed it, with the SPC logo facing out. So a more competent shop/tech should be able to manipulate the adjuster on the UCA in conjunction with factory adjustments in the LCA I assume?
03 Limited V8 4WD
Old 10-23-2014, 10:04 AM #14
chmura's Avatar
chmura chmura is offline
chmura is on a distinguished road
chmura's Avatar
Get a alignment. This will help with the body mount. Put the caster all the way up.
I have 285/70/17 BFG KM2 MT's and I do not rub the body mount. I think alignment is a big factor here. If I get a bigger size tire than this I will definitely rub the body mount and will need to do a chop.
I just recently switched out my rims to a better offset and I still don't run the body mount with the new wheels.
2009 Trail Edition - ICON lift, Total Chaos UCA, BF Goodrich Mud Terrain KM2 285/70/17's, SCS Stealth 6 Matte Gunmetal finish, K9 2.2m Roof Rack.
chmura is offline   Reply With QuoteReply With Quote
Old 10-24-2014, 10:51 PM #15
ARunner's Avatar
Real Name: Kyle
ARunner's Avatar
Real Name: Kyle
Alignment done and a good 6 degrees of caster is dialed in. Shops broke driver side abs wire. Rewired myself because no Toyota dealers have them in stock. Wierd behavior now out of dash lights. VSC TRAC and ABS flash in an alternating fashion when not rolling. When I start rolling the VSC OFF and VAC TRAC lights are lit up continuously and ABS is not lit. Any ideas? More importantly, is it safe to assume my ATRAC will be completely disabled tomorrow when I need it?
03 Limited V8 4WD
Body Mount Bushings Pikeman 3rd gen T4Rs 4 01-19-2014 10:32 PM
is body mount chop the only thing i can do?? silversx 5th gen T4Rs 11 07-28-2012 08:40 AM
Body Mount Bushings???? Project99 3rd gen T4Rs 1 03-05-2010 10:44 PM
NV002-04 03/17/2004 Body - Body Mount Noise CBR_GUY_IA TSB 0 07-12-2009 10:34 PM
