Originally Posted by ben550
What did your mechanic charge for the labor? Did you ever resolve the issue?
Hi again, I recently re-opened this issue with my mechanic. We looked up the DTC codes (P0156 and P0157), both of which point to an issue with bank 2 sensor 2 (lower passenger side on the V8).
He told me to order the OEM part, Denso 234-4261, which includes the electrical connector. I got it through Amazon for less than $50, and he installed it for $20. The old part didn't appear in good shape and could have been the original sensor with 185k miles on it.
Since then, I've driven about 400 miles including expressway, which should include at least the two required driving cycles. (I also performed a zero-point calibration to prevent the whole Christmas tree from lighting up.) So far, everything seems to be fine and no codes have appeared!
In conclusion, I think it was a coincidence that the sensor failed around the same time as the exhaust manifold replacement. In case the problem resurfaces, I will follow up again.
