View Poll Results: V-6 MPG post em up!
Less than 10 MPG
0 |
0% |
10 to 12 MPG
0 |
0% |
13 to 15 MPG
13 |
14.44% |
16 to 18 MPG
41 |
45.56% |
19 to 21 MPG
28 |
31.11% |
22 to 24 MPG
7 |
7.78% |
Over 24. (please tell me how you do this!)
2 |
2.22% |
2 |
2.22% |
02-11-2005, 09:21 PM
V-6 MPG Post up!
I checked my MPG today and it was a whole 16.5 mpg. Mostly highway, some city driving. I want to compare to your alls average MPG. post up please!
2006 Limited V-8 4WD Nautical Blue 122k and counting.
265/65R18 LT BFG All Terrains, ICON Stage 1, SpiderTraxx, WeatherTech Liners, Demello Hybrid Sliders Kenwood DNX-890HD.
02-11-2005, 11:32 PM
I've only managed to get slightly over 24 a few times so I put in mine for 22-24.
Current Mileage: 31,000
Fuel: 91 premium
Oil: M1 Synthetic 5W-30
Tire PSI: 32
Driving Style: Relatively conservative with occasional "outbursts" when somebody pisses me off. I'm usually driving around 60-70mph
Driving: 95% highway with my commute being 100 miles round trip.
Last 3 fill ups: 23.06, 24.63, 22.65
Here are my findings: My mileage increased a bit after 20,000 miles. You get the best mileage driving at 50-55 mph and mileage decreases rapidly past 70mph. The bug deflector helped the mileage slightly.
EDIT: I edited to include some more info about the way I drive.
2003 4Runner SR5 V6 4x2 - Pacific Blue Metallic/Taupe Leather
02-12-2005, 12:23 AM
Since I bought my 4runner in Dec, I'm averaging 19-21mpg. I do mostly 85% hwy driving(I average 2500-3000 miles a month). I've also noticed that if I use regular grade, my mpg drop about 1-2 mpg. I stay with premium and with the better gas mileage, I end up paying half of the difference in cost. Cruising at 70mph also makes a big difference.
2005 4Runner Sport Edition V6 2wd
Titanium Metallic, Moonroof, JBL 6 disc 10 speaker system, double decker cargo.
Mods:
Toyota All Weather Mats
Rear Gear Cargo Area Liner
Valor Exhaust Tip
OBX pedals
Sylvania 9006ST- Low Beam/Fog Lights
Sylvania 9005ST - High Beam
Yakima LoadWarrior
Safari Light Bar
PIAA 520 SMR Driving Lights
Brigdestone Dueler A/T Revos
02-12-2005, 12:52 AM
why is it that some people get 24mpg and others (like me) get around 16.5?
I realize that the way you drive as well as the speeds (roads) you are driving on make a difference, but 7.5 mpg difference?!
Toyota 4Runner 2004 SR5 V6 (Silver)
Exterior:
35% tint on front 2 roll downs, Manik grill guard, Manik tail light guards, Silverstar low beams, Silverstar fog lights, Hella 500 Driving Lights, WARN Shackle Hitch, 265/70/17 BFG AT KO, Cornfed 3/2, 3FT Wilson CB Antenna
Interior:
Clarion DX745MP headunit, 2 12" Visonik subwoofers, 1 1400watt visonik amplifier, Uniden CB, Valentine 1, Blinder M-20 Xtreme Jammers, Husky Floor Liners (front only)
02-12-2005, 01:55 AM
'04 V6 Ltd 4x4 (mpg specs are for 2wd mode, I only put it in 4HI in bad weather)
Driving style: 75% aggressive; 25% moderate
Average highway speed: 80-90mph
Fuel: premium 91
Oil: synthetic (M1)
Daily commute: 95% highway, 5% city (usually 150miles to 250miles daily; 3,500 to 4000 miles monthly).
here's several scenarios/setups that I've encountered:
1) stock from dealer (dunlops @ 32psi): 20-20.5mpg
2) stock from dealer (tires @ 40psi front; 38psi rear): 21mpg
3) addition of Yakima Megawarrior basket w/extensions (tires @ 32psi): 16mpg (way too much drag, especially at higher speeds)
4) addition of Sunroof Wind Deflector (improves aerodynamics & noise levels of the installed Megawarrior basket) tires @ 32psi: 17.5mpg
5) addition of sunroof wind deflector (same as #4, but tires @ 40psi front & 38psi rear): I will soon find out after several fill up
my current configuration is #5
all mpg figures are hand calculated, display readout is usually 1.5-2mpg higher. I usually refill the tank when there's 1/4 to 1/8 of a tank remaining.
future setup #6) add on the front hood protector/deflector, may improve aerodynamics a bit
02-12-2005, 01:59 AM
In the city, my best doing 50 -55mph, and not rev over 2k rpm I have gotten 18.4 mpg
Revving over 2k rpm and driving about 60, 16.4 - 17.8 mpg
On the highway, my best milage is always holding steady at 70 mph.
-2K34R
2004 4Runner SR5 V6
Stratosphere Mica
Westin Safari Bar, 20" Enkei w/ 285/50/20 Yokohamas, 15% Window Tints, OEM XM, IPOD & AUX with Scion HU, 1995 & 2005 Chrome v6 Emblems, Toyota Hood Protector, Spoiler, AVS Tail Light Covers Painted, Passport Escort 8500 Radar Detector, Borla Dual Exhaust, Cornfed 2"/3" Lift
02-12-2005, 02:21 AM
I average about 18 miles per gallon, but that's with about 75% stop-and-go driving on backroads.
On a long highway trip, I average about 22 miles per gallon. I could probably bring that up a little, but I tend to mash the pedal once in a while
2004 Sport 4x4 Galactic Gray
02-12-2005, 02:24 AM
Well, I'll tell you one thing for sure-- all these people that changed their tire size to 265/70-17 do not get accurate mileage figures because their tires are 1 inch taller than stock.
That's enough to make a fairly significant difference in mileage figures....
02-12-2005, 04:42 AM
I have about 2500 miles and use 91 octane and only get about 17 miles to the gallon. I do both highway and city driving and I'm pretty easy on the pedal. But I think the thing that affects my mpg the most is I usually warm up my 4runner for 5 minutes.
Paul
05 Titanium Metallic Sport Edition V6 4X4
I need a better job to get more mods.
02-12-2005, 07:51 AM
so would that make the milage "appear" on paper better or worse? I just cant understand why there is such a gap in our mileage. I will play with tire pressure to see if that does anything.
I just ran some injector cleaner through as well as a take of premium. I only have 18,500 on the clock , so maybe Im starting to get her broke in ..... i dunno, i just expected a little better mileage.
02-12-2005, 10:52 AM
I usually get between 15 and 16, mostly around town driving. On the road trip from San Diego to Reno, I averaged about 23 MPG.
Why are you guys filling up with 91 octane?
Matt
2000 SR5 Sport Edition
Imperial Jade Mica
Team Hinga California
02-12-2005, 11:22 AM
20 mpg here always (mixed driving). Interesting observation though: lack of fifth gear means drop in gas milage at speeds over 75 mph, bomer...
02-12-2005, 12:16 PM
I didnt think about that, all 2004 V6's have the 4 speed auto right?
02-12-2005, 01:02 PM
The stock tires (265/65-17) do 660 revolutions per mile (circumference is 96 inches)
The tires that a lot of people here are running (265/70-17) do 638 revolutions per mile (circumference is 99.3 inches)
This will make the speedometer/odometer 3.4% too slow, due to the larger tires.
If a full tank of gas lasts for, say 300 miles, the difference in revolutions between these two tires sizes is 6,600 for just that one tank of gas !!
02-12-2005, 05:01 PM
All city and Autobahn
Right at 17.
Best was on a recent trip averaging about 90 - 95 mph and I got 21.7 there, through the mountains.
When I was still in the states I got 24 on a trip averaging about 70 from Cocoa Beach Florida to Louisiana, it was about 2100 miles round trip.
I'm adding the Gen 2 FIPK and every time I've had it on a vehicle before it has added at least 1mpg in the city and 2-3 on the highway trips, can't wait to add it
T
Lots of 4Runners, but just picked up 2020 Tacoma TRD Sport 4x4 with Manual Trans in Quicksand
