Originally Posted by Sungod
I know physics and I also know reality. I know there is such thing as a 1.0 earthquake on the Richter scale and a 2.0 is 1000 times stronger, but you won't feel either. The difference between the two rotors is miniscule and you are not going to notice the difference.
I know this is a very old thread, but I need to correct this misinformation.
I won't bother with the misstatement regarding the Richter scale, but I will say that the difference between the two rotor sizes is definitely not miniscule. If you had calculated the surface area provided by the extra 19mm of diameter you would know this:
Surface area of 319mm standard rotors = 123.8 sq inches
Surface area of 338mm sport rotors = 139.1 sq inches
This is a difference of 15.2 sq inches, which is a 12.3% increase in swept braking area. Also there is greater mass (larger heat sink) which decreases brake fade. Heat is the number one enemy of brake efficiency. Larger rotors will provide lower peak temperatures and longer wear cycles between brake pad changes (lower maintenance costs), as well as significantly better braking ability. All this in addition to the larger rotor giving the brake pad greater leverage and efficiency. So you can see that the larger rotors give advantages on several levels.
The Sport brake upgrade is not miniscule and is absolutely worth doing.
