Originally Posted by Capt Kirk
Kinda late and not sure but my Valet key will start my 4runner, the key is Gray with a stamped dot in the metal portion of the key. IT WILL NOT allow the security "ECU" to go into program mode, but it will start my 2006 4runner. I was under the impression that a "Valet" key would only open the doors, NOT START the engine. Any body else experiance this issue??
Not sure where you got that info for the gray "Valet" key, the gray valet key WILL unlock the doors, the gray valet key WILL start the vehicle....but the gray valet key WILL NOT unlock the glove box so the "valet" can't steal anything of value you have locked in the glove box, the purpose of the valet key is to allow the valet to take your vehicle park it and then return the vehicle to you when you're ready to leave, but doesn't allow him/her to go into the glove box to get at your valuables.
This info about the gray valet key not unlocking the glove box and using it for a valet is in your owner's manual but it's referred too as the gray "Sub" key.
To program another key you need to use a "Master" key which is the black key, a gray valet key will not work for programming a new key.
Both the Master key and the Sub "Valet" key have chips in the head to allow them to start the vehicle.
