Old 07-05-2012, 12:52 PM #1
sina518 sina518 is offline
sina518 is on a distinguished road
Steering wheel shake, need help
all right i have a 05 4wd sr5, i recently installed a daystar 2.5/1.5 and put cooper discover ATP 265/75/16. when I get to about 60mph the steering starts to shake. i had the wheels and tires rotated and balanced and it still does it. My next step is to have High speed balancing done. but before i dish out $120 dollars, have any of you had this issue and what was done to fix it. all help and advice is appriciated .
sina518 is offline   Reply With QuoteReply With Quote
Old 07-05-2012, 12:53 PM #2
Oh and i also replaced rotors and pads in the front and rear.
Old 07-05-2012, 12:59 PM #3
Darklight's Avatar
Darklight Darklight is offline
Darklight is on a distinguished road
Darklight's Avatar
Did you get an alignment done after the lift was installed? It could be related to the issue, that an possible a wheel out of balance.
2008 Black 4X4Runner SR5 V6, Total Chaos Race series 2" plus kit, King 700 lbs LT coilovers & MetalTech stage 5 LT rear, 315/75R16 KM2, Strike 6 16x8.5 -6 wheels , Demello offroad 3 hoop, 4X4Labs rear, ATO, RCI ,BudBuilt, Stubbs sliders, 4Crawler B/L 3/4", MagnaFlow , K&N , Speski barrier, sPOD, ARB CKM12, ARB locker front/rear 4.56 gears WMW roof rack
Darklight's Build
Darklight is offline   Reply With QuoteReply With Quote
Old 07-05-2012, 01:24 PM #4
alignment was done, and wheels were balanced, and balanced again at discount tire.
Old 07-05-2012, 01:40 PM #5
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Make sure they use the finger plate adapter. Discount tire does not believe it needs to be used on factory wheels. However, it does, according to Toyota Service bulletin SU002-96. A finger plate adapter is also called a Haweka Adapter. Once I asked Discount Tire to use the adapter on my 3rd gen the steering wheel shake went away.
HAWEKA
Of course the vibration could come from several causes, this is what worked for me.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 07-06-2012, 12:33 AM #6
okay great, thank you. I'm just trying to rule somethings out before i go dish out money.
Old 07-06-2012, 01:26 AM #7
T4RAddict's Avatar
T4RAddict T4RAddict is offline
T4RAddict is on a distinguished road
T4RAddict's Avatar
Read this: Steering Wheel Vibration? THE solution to the problem!
2004 Sport V6 | DS 2.5/1.5 | 265/70 Duratracs | Pioneer 3300BT | Tinted 20% | Painted Roof Rack |
T4RAddict is offline   Reply With QuoteReply With Quote
Old 07-06-2012, 02:10 AM #8
good info thank you, i purchased the lifetime balancing and rotating on the tires through discount so ill take it some time this week and ask them to do the dynamic balancing. assuming that is not what they did the first time and I'm pretty sure it wasn't.
Old 07-14-2012, 03:16 PM #9
BootyFister's Avatar
BootyFister BootyFister is offline
BootyFister is on a distinguished road
check your cv shafts!
you may have a broken bootyfister.
Your experiance is exactly what I did, until i saw the boots. I replaced the left one first now the passenger on monday. they gave my wheel the shakes at 60 MPH. Good luck
BootyFister is offline   Reply With QuoteReply With Quote
Old 12-19-2012, 03:26 PM #10
jamr212 jamr212 is offline
jamr212 is on a distinguished road
So, did the balancing with the Haweka adapter work? I am having the same problem and wanted to know the results......please say it worked!!
jamr212 is offline   Reply With QuoteReply With Quote
Old 12-19-2012, 04:55 PM #11
stevec5000 stevec5000 is offline
stevec5000 is on a distinguished road
That's the problem, you need to have the wheels balanced PROPERLY!
Or just get a balancer at Harbor Freight and do it yourself to make sure it's right.
stevec5000 is offline   Reply With QuoteReply With Quote
Old 12-19-2012, 05:46 PM #12
Sungod Sungod is offline
Sungod is on a distinguished road
The Haweka adapter isn't as important as this: Toyota Plate 6 Bolt x 5.50" | COATS 40mm Wheel Balancer Adapters, Cones, Face Plates
The cone is the problem. My local shop has this cone that is used specifically for Toyotas and I have never had an issue getting them balanced perfectly.
Sungod is offline   Reply With QuoteReply With Quote
Steering wheel shake/vibration fortworth4x4 4th Gen T4Rs 4 04-07-2011 01:21 PM
[video]...Lexus IS350 Steering Wheel Shake K.C. General Discussions 16 02-11-2010 09:38 AM
Steering Wheel Shake r3dh3ad84 4th Gen T4Rs 1 06-12-2009 02:26 AM
steering wheel shake rayny1014 3rd gen T4Rs 1 09-17-2007 09:39 PM
Steering shake/vibration kas10 Problems & Warranty Issues 2 11-02-2003 05:44 PM
