07-13-2012, 06:51 PM
Real Name: Dennis
Real Name: Dennis
Defective Paint and Peeling Clearcoat!
Hello All,
I have a 2006 Toyota 4Runner Limited in red salsa pearl. I have had it now for a year and started taking the time to really detail it with my PC 7424XP. Unfortunately, I have what looks like peppered white marks and spots all over the hood and roof area above the windshield. The clear coat is flaking off on the roof. The sides and back area are in great shape. I have clayed it then compound, polish, and wax, but no such luck in getting rid of the spots. Someone recommended light sanding with 1500, 3000 grit sandpaper then polish, so I tried this and it didn't work.
Has anyone else here have the same problem with their paint and clearcoat? If so what have you done to correct it or would it come down to just taking it to a paint and body shop?
I welcome any suggestions and tips.
Thank You,
Dennis
07-13-2012, 07:14 PM
It looks like is is time for a repaint to me. It must have not been in a garage or waxed much before you got it.
07-13-2012, 08:25 PM
Are those pictures after you buffed it with a wheel or a DA and compound? If not, then you can do that. Wet sand first with 2000 grit until the marked go away, then polish with a rotary buffer or a DA (little safer). Obviously you are without clear in those areas but it should look better than that. If that doesn't work then you need to repaint.
2004 4Runner 4x4 v6 SR5 Black w/Leather Bilstein 5100/FJ Swap @ 1.75
1998 4Runner 4x4 v6 SR5 Rear Locker Desert Dune Pearl w/Leather
07-14-2012, 11:27 AM
You live in Fla. That isn't shocking.
07-14-2012, 11:31 AM
Did you buy this new?? Was there always good wax on the car during it's lifetime. A car that's in the sun a lot that's not properly waxed...the paint can be permanently damaged in very short order. Your vehicle is now 7 years old. Either live with it or get it repainted.
07-16-2012, 12:24 PM
Real Name: Dennis
Real Name: Dennis
I dont think the original owner kept it in a garage either. Unfortunately I am not able to garage it either. I do keep it washed weekly and waxed.
07-16-2012, 12:29 PM
Real Name: Dennis
Real Name: Dennis
Yes, these were taken after claying, then buffing with Meguiar's 205, 105, finally wax. I'm thinking repaint is going to solve my problem. Flaws like this in my T4R drive me crazy
07-16-2012, 12:32 PM
Real Name: Dennis
Real Name: Dennis
Not at all, this is the worst weather for our rides! It's hot, humid, rainy, and I live close to the water which doesn't help with the salt.
07-16-2012, 12:36 PM
Real Name: brian
Real Name: brian
ive seen this before. unfortunately it can be caused by a number of things and the only solution is a repaint.
the possible things it could have been is tomething sandblated it and over time it got worse, something got sprayed on it and over time it got worse or it was repainted at one time and it had moisture under the paint and over time the moisture finally broke through and got worse.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
07-16-2012, 12:38 PM
Real Name: Dennis
Real Name: Dennis
I bought it used at a local dealer. It was traded in by the original owner. I don't know how well the original owner took care of the body, but I have been caring for it the right way since I bought it last year.
07-16-2012, 12:44 PM
Real Name: Dennis
Real Name: Dennis
I was thinking on those lines too! The way it looks starting on the hood and then over the whole roof area like something sprayed it. The sides of the vehicle and rear hatch is in great shape with the exceptions of a few minor scratches that can only be seen up close.
06-09-2020, 08:39 AM
Salsa Red Pearl Paint Peeling
We have same problem with 2007 4Runner. Clear coat peeling off hood and roof. Toyota has a paint recall but they are telling me mine does not fall under recall. They stated recall is for white models only.
06-09-2020, 01:56 PM
I thought white was single-stage (no clear coat)?
06-09-2020, 03:10 PM
I also have an 06 in Salsa Red Pearl and have the same issue. Once the clear coat is gone the only solution is to repaint.
It is, but the recall is for their "White Blizzard Pearl" which does have a clear coat.
06-15-2020, 06:16 PM
2005 grey here. Hood was shot so I picked up 2 part clear for about $80, sanded and shot the paint on. I'm not the best painter, and I was worried it would look too new, but I got just enough orange peel to match the 15-year-old factory paint on the rest of the car. Was a 3 hour job.
My roof is way shot and my tailgate is getting there but I've been lazy. Took about 1/2 quart for the hood and I'm afraid I'll run out on the roof if I start that project.
Good news on a roof is nobody sees it so it doesn't have to be a great job, just needs to keep it from rusting. https://www.toyota-4runner.org/attac...024_161021-jpg
