07-23-2013, 01:18 PM
#16
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Thanks guys. Will have to check them out
07-23-2013, 02:13 PM
#17
I have a set of BAMF with kickouts on order. Hopefully be here in another 6-8 weeks.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
07-23-2013, 02:54 PM
#18
Originally Posted by HokieRunner
Do you have any pictures? I've seen a few but am picture greedy haha
Also - do you have the HREW or DOM?
They start at $460 bare metal. Stronger tubing/powdercoating options range up to $600.
I ordered the HREW because I honestly don't see myself bashing them that hard. I'll try and gather some pics and post them up here this afternoon.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
07-23-2013, 03:35 PM
#19
Real Name: Matt
Real Name: Matt
That's the way I'm leaning. And thanks so much! I actually found another user on here Adventure_Copan who has them on his rig with the full top plates.
Spoke with John at White Knuckle too - great guy and very helpful.
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
07-23-2013, 04:31 PM
#20
I ordered White Knuckle sliders about 2 weeks ago. They should be shipping out very soon so I'll hopefully have them next week. Will provide lots of pics.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
07-23-2013, 09:57 PM
#21
07-23-2013, 10:55 PM
#22
I'd be interested I see how the install goes and your feedback on them. Please keep us posted
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
07-23-2013, 11:21 PM
#23
I've never heard of them, but I must say they are very appealing.
07-23-2013, 11:59 PM
#24
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Some pics from when I first put them on. These pics are actually on whiteknuckle's web site.
Very nice.
Can you do me a huge solid if you have a chance and measure between the back two braces?? Also, the height from the bottom of the rectangular mounting plate to the base of the pole that connects it to the slider?
Trying to figure out if these will work with XREAS. Spoke to John Yesterday and *seems* like I can make it happen.
07-24-2013, 01:23 AM
#25
Originally Posted by zopperman
Very nice.
Yeah, I'll see if I can get under there and get some measurements for you tomorrow. The only portions of my XREAS that was left when I went to install these sliders were the the plastic push brackets that hold all the lines in place. I know I had to pop off a good number of them to clear space for the sliders to bolt against the frame rail. I'm guessing you could probably make it work with the XREAS still installed, but weaseling the mounting flanges behind/between the lines will probably be a bit of a trick. I can take some pictures of the areas where the flanges and U bolts fit around the frame rail as well if you want.
07-24-2013, 02:48 AM
#26
Will do. I'm getting them on Monday, they just shipped
07-24-2013, 07:55 AM
#27
Real Name: Matt
Real Name: Matt
Thanks for the pictures! I somehow glazed right over the customer rigs section on John's website.
After seeing the pictures and talking with John, I'm definitely sold. Looks like I'll place an order next week and I'll post up my thoughts when they come in. Going with the top plate option - I really like that it's removable, doubles as a step and also offers added protection from on/off road debris.
07-24-2013, 09:20 PM
#28
Very nice.
Lemme know if this helps.
07-24-2013, 09:39 PM
#29
Moderator
Real Name: Zak
Moderator
Real Name: Zak
You're the man. Thanks. It does, but I also need the pole thickness if you have a chance. As well as the distance from the lower link to the first mount (closes to back) kind of on a diagonal i guess would be the best place to measure it from? So I can get an idea of where the slider mounts in relation to the reservoirs. Let me know if that makes sense?
I'd DEFINITELY want to run the hydraulics above the slider so that they don't get crushed by rocks...
I can see where your fluid reservoirs were mounted
07-24-2013, 10:19 PM
#30
The "poles" are 1.5" square tube. It's roughly 7.5" from the center of the forward lower link bolt to the rear edge of the rear slider mounting flange.
