Originally Posted by soundstudio315
Just want to be sure what exactly it is that i may need to loosen or remove on rear daystar install.
Not sure why you need to loosen the panhard bar. I've done spacers in the rear of my 4runner as well as 2" springs on a 5th gen and the Panhard bar did not need to be loosened or removed.
You will need to disconnect the sway bar though. I found disconnecting at the endlink is the easiest.
06' 4runner 2wd v6 w/excess pee wheels
