Old 08-01-2012, 07:36 PM #1
br2355 br2355 is offline
br2355 is on a distinguished road
Steering is sticky, wont return. Noisy too
My 04 steering is sticky and wont return after I release the steering wheel.
It is also making a whirring noise when I move, almost as if I have studded snow tires, but it abates a little when I turn to the right.
Some say its the power steering pump, others say the rack and pinion, others say the steering box.
Any suggestions?
thanks
br2355 is offline   Reply With QuoteReply With Quote
Old 08-01-2012, 07:44 PM #2
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I can tell you for sure its not the Steering Box, 4th Gen 4Runners use a rack & pinion setup, vs the old recirculating ball style.
What do you mean it doesn't "return?" Normally the steering will straighten a little when left alone, but its not supposed turn itself all the way.
I would check your power steering fluid and see if it is properly filled, if at the proper level; does it smell burnt or look contaminated with particles? Then have someone turn the wheel back and forth while parked with the engine running and listen to the powersteering pump, it should make a slight whine, but nothing extremely loud or horrible sounding.
If you can get the vehicle on a lift or jacks I would inspect the lines leading from the power steering pump to the rack & pinion. Also while you have it up in the air, inspect the suspension components as things like balljoints, tierod ends, and such could be causing a binding issue.
Some more information would also be helpful, I am assuming your vehicle is running stock suspension, tires, wheels, brakes, ect.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 08-01-2012, 08:49 PM #3
Any suggestions?
thanks
I have to turn the steering wheel back to center, it wont return on its own at all.
Everything is stock on the truck.
Thanks for the info...
PWR Steering Return/Pressure Line, $$$ Expensive, Any info... daugherty83 3rd gen T4Rs 8 05-28-2016 10:59 AM
Power steering pump noisy with brakes on. Sepacal Classic T4Rs 10 01-17-2011 04:37 PM
Noisy & I mean NOISY Fuel Injectors!! Spartan57 Classic T4Rs 4 05-13-2005 10:03 AM
