Hey all, I'm having a similar issue as this member here in this thread:
2005 4Runner Center Consloe stays open?
The small spring loaded cover stopped working for me so I took it apart to take a look and do my best at fixing it, and my nightmare came true. The spring popped out before I could get a decent look at how it was originally put together.
All I need is somebody to pop out their box and take a picture of it (assembled) so I can see how it goes together. Don't worry, nothing will pop out of its place. The little box is held in by two clip type things; no screws or anything. If you're feeling so kind as to do this for me, please take as many pictures as you can with as many different angles of the side opposite of the power outlet.
Here are the parts that sort of sprung off:
And here is the view/angle that I think would be most beneficial in a picture from you guys. This is a picture after I put the parts back on...the way that I think they go. Only issue is the spring. Again, nothing will pop out on yours unless you remove that screw in this picture...which you shouldn't need to for this.
I can't find any blown up diagrams for this part, and if this (last resort) call to the forum doesn't work, I'll be buying
this to replace it. If anyone helps me with this, I'd appreciate it so much.
