Originally Posted by boondoggle
Seems odd to me they would put larger rotors on but, from what I understand, the pads are the same size as other models. So, my pea brain tends to think I'm getting the same amount of friction when the brakes are on. It's still a two piston caliper from what I've read.
Other than perhaps better heat dissipation due to more mass and larger surface area, I don't really see the point. I'm not a mechanical engineer though so maybe I'm missing something.
The point you are missing my friend is
leverage.
The further out you can position that same size pad, the more leverage it has using the same two pistol caliper.
The load it has to stop is (W)
The rotor is (F)
The 2 pistol caliper is (P)
The larger rotor allows the caliper to work more efficiently. Using less effort to do the same job and therefore increasing your overall breaking headroom.
