Old 03-27-2017, 04:48 PM #31
Johnnibanner4run's Avatar
Johnnibanner4run Johnnibanner4run is offline
Real Name: Jonathan Abrego
Johnnibanner4run is on a distinguished road
So I was reading this and I'm confused on torque bolt specs and sealer.
Sent from my SM-G935P using Tapatalk
Johnnibanner4run is offline   Reply With QuoteReply With Quote
Old 08-05-2017, 12:44 PM #32
Tex-Tac Tex-Tac is offline
Tex-Tac is on a distinguished road
Sub'd
Tex-Tac is offline   Reply With QuoteReply With Quote
Old 10-21-2017, 12:44 PM #33
4Rnr4Evr's Avatar
4Rnr4Evr 4Rnr4Evr is offline
4Rnr4Evr is on a distinguished road
4Rnr4Evr's Avatar
After I changed my plugs last night I found the same oil leak. I will be doing this soon. I've already some experience with taking the intake assy off and it wasn't particularly hard. Plan to replace all bolts I can as well.
no more T4R...
4Rnr4Evr is offline   Reply With QuoteReply With Quote
Old 10-21-2017, 03:42 PM #34
Supersonic Supersonic is offline
Supersonic is on a distinguished road
Yes get inch pound torque wrench and be careful, as stated bolt B is inner 3, bolt A is perimeter bolts. Instructions read " Tighten the bolts and nuts uniformly in several steps."
Going to do this soon too, but also add checking the valve clearance. I usually do the spark plugs as they are easier to get at, but seems the plugs are recently changed. You may also want to do this to ease any anxiety about wear, it is a fairly easy task to adjust if necessary.
Unlike the bucket type in the 1.8 Matrix, I also got ~300k on that one two, but mercifully both have no unusual noise, which I think is the test for some, at least on the Matrix ain't nothing happening to adjust the buckets unless the heads come off.
Should just be a shim to replace on the 4.0 V6 4Runner if adjustment is needed, though I am not there yet.
Anyone got tips or links to "checking the valve clearance" and could add here would be greatly appreciated.
Originally Posted by Joemce View Post
WHOA! Hold it! You will break those valve cover bolts. I'm trying to send you the FSM page but that 137 Kb limit is way too small. "Bolt B" are the 3 bolts in the middle. You are supposed to put "seal packing" on the timing cover joint also. I assume that is an RTV or gasket maker.
Torque: For bolt A
10 N*m (102 kgf*cm, 7 ft.*lbf)
For bolt B
9.0 N*m (92 kgf*cm, 80 in.*lbf)
For nut
Supersonic is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 09:28 PM #35
FyCkD FuNnY FyCkD FuNnY is offline
FyCkD FuNnY is on a distinguished road
Thank a lot... Really helped me...
2003 4Runner Sport V6 2wd, now over 344k+ miles...
2nd owner, running like a champ...
Latest Intall:
Toyota Shocks in the Rear and Bilstein Struts in the front
Removed the Original XREAS Shocks
FyCkD FuNnY is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 11:53 AM #36
Badbert Badbert is offline
Badbert is on a distinguished road
Great pics. Thanks.
Badbert is offline   Reply With QuoteReply With Quote
Old 11-28-2021, 09:06 PM #37
AFisher AFisher is offline
AFisher is on a distinguished road
Informative!
Hi, thanks a ton for the photos explaining this. Think I'll be attempting this in the not distant future.
AFisher is offline   Reply With QuoteReply With Quote
Old 03-14-2022, 10:55 AM #38
Swimupstream Swimupstream is offline
Swimupstream is on a distinguished road
FIPG vs RTV? I have RTV already. And one earlier poster asked about high temp red which I also have on hand from water pump.
Thanks for the clarification on a in/lb torque wrench for that lower spec.
2005 4R SR5, 4WD V6
Clearly I'm not a motorhead, like spending as little as possible, but don't mind working and trying new things.
Swimupstream is offline   Reply With QuoteReply With Quote
Old 03-15-2022, 07:59 AM #39
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I used permatex black meant for oil. Buy a small tube, you only need 2 tabs on each side. Clean the metal surface of the head with acetone so you get a good bond.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Valve cover gasket replacement slipknoter106 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-13-2011 08:38 PM
Valve Cover Gasket Replacement FirstGenRunner Classic T4Rs 12 09-22-2011 12:34 PM
Valve Cover Gasket Replacement Help aggieoutlaw06 4th Gen T4Rs 1 10-17-2007 07:31 AM
