Old 10-20-2013, 11:35 PM #61
VladCZ VladCZ is offline
VladCZ is on a distinguished road
Originally Posted by 4-Legged-Runner View Post
I absolutely, guarantee if anyone has had their windshield replaced and the reveal molding fastener was removed/not replaced - you will get water on your front floors. If not, the each vertical side of the windshield would have to be filled with a toothpaste tubes worth of caulk.
I cannot believe the engineering that went into the design of the A-pillars. There are THREE holes that the reveal molding fastener snaps into - two holes near the TOP of the A-pillar and one hole near the bottom.
Vlad - the A-pillars have three holes!!!
I have purchased the molding fastener and now must have the windshield removed to place the fasteners into position.
More to come...
I know Matt but only 2 of them were partially exposed - the 3rd one was completely covered by the glue already.
I am just amazed by "professionalism" of some glass shops ..... I'm a licensed trained commercial and car mechanic in my country in Europe - if I ever did anything like that in earlier years working there I would loose my job immediately that hour! I'm not saying everything is perfect there but lack of any accountability and absolute disrespect of so many repair shops at this continent is just blowing my mind away ....
VladCZ is offline   Reply With QuoteReply With Quote
Old 12-23-2013, 11:39 AM #62
phishtaco phishtaco is offline
phishtaco is on a distinguished road
Originally Posted by VladCZ View Post
OK, happy to inform you that the problem of wet floor is solved (with help of many people here giving their input - thank you guys for that)
I discovered, after pulling out the side windshield weatherstrip away from A-pillar, that there were 2 holes partially covered by glue when windshield was replaced (sometimes in past). However, they were not plugged by anything nor fully covered by glue. They were just open right to the A-pillar!!
Assuming (hoping) this could be the entry for the water seeping through I used marine silicone and sealed both holes, let it dry overnight and tested it with garden hose for over an hour - floor came out dry. No signs of any water anywhere.
When I was hosing down the windshield before, water appeared on the floor in few minutes. I could also see water seeping through between metal edge of A-pillar and the glue (of the windshield).
So I hope I'm done with this issue. I post few pics of the holes - 1st of the pics was taken from the roof-down direction so don't get confused. Somebody here mentioned 3 holes - I saw only 2, maybe 3rd one was covered by the glue already ... Either way - how could glass guys replacing the windshield miss that???
BTW, an interesting article about quality of glass replacement shops: Why auto glass service isn't all it's cracked up to be - The Globe and Mail
What's the best way to remove this windshield trim to access these holes to fill? After multiple different tests I've come to the conclusion that this is where my leak is coming from. Thanks.
73 FJ40 35" Krawlers, Locked, Longs, 8274
04 4Runner V8 Sport, 285s, FJ Cruiser wheels, 5100s, Superflex
phishtaco is offline   Reply With QuoteReply With Quote
Old 02-20-2014, 01:49 AM #63
I just opened the hood, removed the plastic cover at the bottom of the weatherstrip and pulled the strip up
Old 02-20-2014, 01:53 AM #64
Check-in after rainy season
I'm pleased to inform that the holes in A-Pillar were definitely source of the leak.
Since I sealed them, there's absolutely no water coming in - and we have a lot of rain poring down during the winter.
Marine silicone is holding up so far ;-)
Old 02-20-2014, 10:16 AM #65
Thanks. I actually had my windshield crack a day or two after posting this. New installation has taken care of my wet floor.
Old 02-22-2014, 05:57 PM #66
black4vcobra's Avatar
black4vcobra black4vcobra is offline
black4vcobra is on a distinguished road
I bought my 4Runner in November and as far as I know it's the original windshield. My driver's side floor has been wet all winter. I just figured it was from the holes in the floor mat but I sealed those and it's been dry lately yet the carpet would be wet. I pulled up the carpet and the insulation pad was SOAKED! I wrung it out and water was pouring out of it. Anyway, I pulled the weather stripping back and my A pillar doesn't seem to have the same holes in it like the other guys who posted in this thread.
Can someone who's been through this give me some guidance on what I should do to correct the leak? tHere are some pics that I took with everything apart.
Floor
Not really pleased about the surface rust. It must have been wet for a long time under there -
A-pillar
These aren't holes, rather just notches. I filled them with sealant anyway.
Cowl. The rubber edging was coming off of the cowl so I snapped it back on.
Drain hole
Firewall
Inside of A-pillar
Thanks for any help guys.
2006 Toyota 4Runner, SR5 Sport package, 4.7L V8, 4WD
Mods - HCF delete, fog light mod, Gibson stainless catback, K&N air filter
black4vcobra is offline   Reply With QuoteReply With Quote
Old 02-22-2014, 07:03 PM #67
Atlanta_man's Avatar
Atlanta_man Atlanta_man is offline
Atlanta_man is on a distinguished road
I had the same problem, passenger side. Front sunroof drain needed the weed eater cord roto rooter.
was: 2005 2wd V8 Limited, one owner (me), 155K miles
now: 2019 Kia Sorento SXL V6
Atlanta_man is offline   Reply With QuoteReply With Quote
Old 03-07-2014, 05:19 PM #68
Brutalguyracing Brutalguyracing is offline
Real Name: 03 v8 Limited
Brutalguyracing is on a distinguished road
how does one remove the outside windshield trim pieces?
right and left sides?
i want to check to make sure the 3 holes are sealed up
thanks
Brutalguyracing is offline   Reply With QuoteReply With Quote
Old 03-14-2014, 10:29 PM #69
thanks
bump ^^^^
also how far should the weed eater wire go into the ac drain line
i can only get about 5" into the drain line....
i don't want to force it, was thinking of using a piece of wire but dont want to wreck anything....
idea's
Old 03-14-2014, 11:34 PM #70
At least 3 feet in my case, probably could have been more but that was enough
Old 03-14-2014, 11:57 PM #71
so do you think i should use a piece of wire to try and push past whats stopping me at 5 inches in?
Old 03-16-2014, 10:18 AM #72
HokieRunner's Avatar
HokieRunner HokieRunner is offline
Real Name: Matt
HokieRunner will become famous soon enough
Real Name: Matt
thanks
Outer trim should just pull off. Unless it was glued down at some point. Definitely do not force the snake down the drain tubes. Sorry if I missed it but are they backing up? You can open the sunroof and slowly pour water into the holes on either side to see if it's draining.
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
HokieRunner is offline   Reply With QuoteReply With Quote
Old 03-16-2014, 05:02 PM #73
sunroof drains are all fine.....
im getting water from either the windshield or ac drain
ran the ac the other day for 30 mins not a drop
tried to run weed wacker wire through it but it would only go 5" into the tube
Old 04-06-2014, 11:15 PM #74
trailrazer's Avatar
trailrazer trailrazer is offline
Real Name: Eric
trailrazer is on a distinguished road
trailrazer's Avatar
Real Name: Eric
Yep... glad I found this thread. Misery loves company I suppose. It's rather annoying having soaked carpet on the drivers side only.
The windshield was replaced by the previous owner. They checked it an ensured me that the windshield was not leaking. I still question that. The sunroof drains are clear. Luckily no rust around the sunroof.
I pulled the trim around the windshield. There is no sign of the holes. I found some white square channel glued between the a-pillar and glass. Previously it appeared to be damp around the a-pillar.
The carpet and floor pan was soaked. I pulled back the carpet and cushion to dry out. Tomorrow I'll try a leak test with the garden hose outside.
I suspect windshield issues, but we'll see. Thanks for everyones input.
2003 4Runner SR5 4WD V6... Sold
2008 4Runner SR5 4WD V6- 5100's FJ Coils DS Spacers - 265/70-17 Cooper ATP's on Ultra Drifter's
http://www.toyota-4runner.org/4th-ge...d-v-2-0-a.html
trailrazer is offline   Reply With QuoteReply With Quote
Old 04-08-2014, 01:40 PM #75
damen damen is offline
damen is on a distinguished road
Thanks for the advice guys. I'm going to go outside and check my windshield now because my truck is leaking the same way.
After pulling the carpet back yesterday, the pad and carpet was SOAKED. I pulled the weather strip back on the windshield from the outside and didn't see any of the holes that some of you have. I have a 97 limited. going to go outside now and see how hard it is to pull out the carpet. i need for it to dry and out and in the mean time see if i can find where the leak is coming from. it's supposed to rain tonight so maybe i'll be able to find where it's coming from.
damen is offline   Reply With QuoteReply With Quote
Thump/Bump sound underneath driver floor? Forza 4th Gen T4Rs 5 08-03-2012 11:25 AM
Driver side versus Passenger side front coil heights terrytcl 3rd gen T4Rs 5 02-28-2012 07:06 PM
A/c Blows warm on driver's side and cold on passenger's side txjohnb 4th Gen T4Rs 2 05-06-2011 09:05 PM
vibration at 50-55 on driver side floor 99Grunner 4th Gen T4Rs 10 06-21-2010 08:54 PM
Anyone? 03 4R AC blows hot on driver side cold on passenger side toylax 4th Gen T4Rs 3 05-25-2008 05:43 PM
