Old 12-13-2021, 03:31 PM #46
Nightshade19 Nightshade19 is offline
Nightshade19 is on a distinguished road
Did you remove your spare?
mine has been blinking and if there is a sensor in the spare and it signals when there's no longer communication - that could be the issue.
Nightshade19 is offline   Reply With QuoteReply With Quote
Old 01-06-2022, 01:20 PM #47
304runner 304runner is offline
304runner is on a distinguished road
Tpms
My TPMS light was blinking so I took the advice of one of the members here. I let the air out of the front left tire and the light went on steady , I reinflated that tire and now the light is still on steady. Did the same procedure on remaining tires and I now have the light on steady. Any ideas ???
304runner is offline   Reply With QuoteReply With Quote
Old 01-06-2022, 01:38 PM #48
Urbanite Urbanite is offline
Urbanite is on a distinguished road
I had the same problem and was told the batteries on those TPMS valves were probably kaput. To replace those valves you could be paying a minimum of $300. So, I decided to totally disable that feature and avoid the headache. It hasn't been an issue since.
Urbanite is offline   Reply With QuoteReply With Quote
Old 01-06-2022, 11:10 PM #49
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
My TPMS would blink after commuting to work. I typically drive my Scion or carpool but occasionally drive my 4Runner. Round trip is about 140 miles. I disabled the TPMS after about a year of that annoying blinking light. I routinely check my tire pressure anyways.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 09-20-2022, 03:32 PM #50
panamapat panamapat is offline
panamapat is on a distinguished road
Smile
Originally Posted by Drunner97 View Post
If you don't want to replace all 5 sensors, air down each tire one by one. If the light goes solid, air it back up and move to the next tire. When the light keeps blinking even though you're aired down, that's the busted sensor. Asshats at discount tire tried to tell me all 5 were bad, told them to piss off because it was only 1 sensor. They changed that one out, reset the computer, and I was on my way.
That is a fantastic way to diagnose which sensor is the culprit that needs to be replaced. I just went thru all 4 tires and spare and found that front passenger sensor is bad. Ordered a replacement on Amazon and Discount Tire will install for $15.
Thanks for excellent posting on how to figure out which sensor or sensors need replacing.
panamapat is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 03:19 PM #51
CaddyCruise CaddyCruise is offline
CaddyCruise is on a distinguished road
I had the same issue. I was tired of the TPMS and manually check my tire pressure regularly so I opted for the TPMS bypass. Very easy and only took 30 mins or so.
CaddyCruise is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 12:02 AM #52
bobbychow305 bobbychow305 is offline
bobbychow305 is on a distinguished road
How do you determine which tpms it's bad?
Sent from my moto g power (2021) using Tapatalk
bobbychow305 is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 12:11 AM #53
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
TPMS bypass?
rwh963 is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 03:01 PM #54
twa318 twa318 is offline
twa318 is on a distinguished road
Originally Posted by rwh963 View Post
TPMS bypass?
Write-up: How to Disable (Bypass) the TPMS
TLR:
Simply unplug the connector under the glove box, jumper the black/white and pink/black wire pins with a small paper clip, put a piece of electric tape over it and leave it unplugged, simple as that.
Takes all of 3 minutes and the light is gone forever, easily reversible if you decide to return to the TPSM at some point in the future.
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 07:18 PM #55
IRONLUNG IRONLUNG is offline
IRONLUNG is on a distinguished road
I was in an hour long traffic jam/commute and mine started blinking too! Did the sensor pic up someone elses low tire pressure?🙃 I'm pretty sure all my sensors have dead batteries, being when I last had the tires replaced, costco said I needed them replaced. Declined it.....
IRONLUNG is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 09:28 PM #56
Real Name: Matt
Real Name: Matt
Very unlikely. I work and live pretty rural. It would start blinking while on the highway in the middle of nowhere.
low tire pressure light ...for the spare tire?????? soimcrazy 4th Gen T4Rs 33 12-25-2018 04:23 PM
Tire light blinking, not staying on cgarrett5119 4th Gen T4Rs 8 03-08-2012 06:29 PM
Tire pressure light on! boostedprozac 4th Gen T4Rs 3 08-05-2009 01:02 PM
Low Tire Pressure Light claydoctor 4th Gen T4Rs 24 02-28-2007 09:19 AM
Tire pressure monitor blinking Wah Problems & Warranty Issues 0 04-25-2004 11:01 PM
