10-06-2012, 04:52 PM
MPG Increase
So I spent the weekend giving my new to me 2003 V8 4wd with 102K miles some much needed TLC. I replaced the timing belt and water pump. Drained and filled the motor, transmission and transfer case and filled with synthetic fluids. Flushed the coolant. Removed a K&N air filter the previous owner had installed and replaced it with a Toyota one. I also cleaned the MAF sensor and removed the HCF from the air box. Lastly I installed new Denso Iridium plugs. After all that I have noticed a pretty good improvement in my MPG. I was getting about 16.8mpg and now I am getting about 20.5mpg (22mpg by the computer). I dont think the transmission fluid, transfer fluid or plugs had ever been changed by the look of it. Two days of work was definitely worth it to get it running a lot better and I am loving the mpg increase. Next I am going to do the diffs which I'm sure have never been changed either.
10-06-2012, 05:25 PM
If the plugs were actually 102k miles old then they were a good candidate as to your increase. But being iridium had NOTHING to do with it. You would have gotten the same results with copper core plugs.
Cleaning a dirty MAF sensor is also a good bet as to your increase gas mileage.
It's always good to change your fluids. But they will have little to no help to increase gas mileage.
10-07-2012, 03:33 AM
Iridium had EVERYTHING to do with it
SOLD Jan/15
03 V8 4x4 Limited, RAS converted to coil w/1.5 spacers, Bilstein 5100's 2.5" setting, 265/70R17 Grabber AT2s, FJ Rims, Custom headers, dual exhaust, 20% tint, HCF delete, VSC off mod, blacked-out headlights, WeatherTechs, TRD shift knob.
10-07-2012, 08:26 AM
Don't our engines require iridium plugs? I know the V8 does.
Current - 2017 TRD ORP. Nautical Blue
Previous - "TRex" - 2004 Sport Edition V8. 2000 SR5 Sport
10-07-2012, 09:14 AM
I have this bridge in Brooklyn for sale.
10-07-2012, 10:32 AM
I know that Iridium had nothing to do with lol. That's what is in it from the factory. I just putting out info on what I did.
10-07-2012, 05:11 PM
And I have this thread that requires some negativity...maybe a couple words in all uppercase letters too!
SOLD Jan/15
10-07-2012, 08:40 PM
Isn't it your bedtime.
10-08-2012, 04:30 AM
Sorry OP, I won't keep this thread off topic anymore, I just couldn't resist winding up the jack in the box. Carry on with your exceptional gas mileage
SOLD Jan/15
10-08-2012, 09:39 AM
Sorry TRDCal...didn't mean to make you cry.
