12-07-2016, 02:43 PM
#136
Real Name: Tony
Real Name: Tony
Originally Posted by 03v8raleigh
Related question: Do the AWD v8's generally last as long as the v6's that run in 2wd, without major repairs? I mean the longevity of the driveline (t-case, differentials, etc). I had a 2000 2wd with 230,000 miles for a few months last year (all I could afford at the time), that needed the whole rear end replaced from worn diff gears, bearings, and u-joints. And it had never even been taken offroad. I ended up selling it instead of paying to fix it. I don't look forward to having to replace all of that mess on my 2003 AWD if it starts to go! I figure it sees a lot more wear and tear over the life of the vehicle compared to the v6 since it is constantly being used and stressed, even as a pavement princess. Of course this is all just conjecture, but has anyone seen a noticeable difference between the two, since people generally drive these trucks to very high mileage?
Of course the engines and main components can go forever on these trucks but when all of the expensive 4x4 parts start to go, I imagine maintaining these things gets very pricey.
Actually you get less stress and wear on the full-time 4wd because it is dividing the power up over the full driveline. U-joints wear, but at $10 you can't really complain much. Differentials and such shouldn't wear out if driving in normal conditions, but as with anything, anything can happen. There's guys consistently getting 300k, 400k+ for miles without major failure. I have 230k on mine with 80k of that from me, abused and offroaded heavily, long highway miles, stop and go traffic, and my stupid heavy foot. I toasted a rear dif, but 35's, soft sand and trying to snatch an F-150 out of 6' of water while pulling uphill... Anything can happen.
Sent from the drivers seat of my 05 4runner.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
12-07-2016, 03:34 PM
#137
Real Name: Tony
Real Name: Tony
Originally Posted by sport2004
If yer getting mud on yer windshield you must be doing something right.
It was really wet and sandy, so not mud per say, but still fun!
12-07-2016, 03:45 PM
#138
Real Name: Ron
Real Name: Ron
Differentials (which are the expensive parts of a drive train) will last indefinitely as long as they are kept full of proper lubricant that is free of contamination. They literally do not wear out as long as the parts are running in the proper oil. Failures are generally due to water/dirt contamination or running low on lube or some type of abuse or overstress.
CV boots wear out, but it's not clear that they last longer when used sporadically, or when running full time. The CV boots on my '94 lasted 200K miles and turned every mile of that. I think the primary failure mode on boots is just age, provided the angles are within reason.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
12-07-2016, 03:54 PM
#139
Real Name: Tony
Real Name: Tony
True, but, if you start offroading or are otherwise rough on your truck, one guy auto races his 4runner, the crush sleeves in the dif can cause the pinion to loosen up and everything to not mesh properly anymore. This is what happened to me. Solid spacer and you're good to go!
12-07-2016, 04:04 PM
#140
Real Name: Ron
Real Name: Ron
Agreed. My post was in the context of the guy who worried about the rear-end giving up after 200K miles of on-road driving. That normally doesn't happen unless something went wrong with the lubrication. There's no reason to avoid AWD/fulltime4WD just because of the extra differential. That shouldn't be a major failure component given proper maintenance.
12-07-2016, 04:18 PM
#141
Real Name: Tony
Real Name: Tony
Yes! I should've clarified better! 👍
12-07-2016, 04:30 PM
#142
Real Name: Matt
Real Name: Matt
The CV joints are turning all the time even on multi-mode 4runners that are in 2WD. 2WD-only 4runners have no CV joints, of course.
2007 V8 Limited 4WD
12-07-2016, 07:22 PM
#143
Originally Posted by m85476585
There are no ill effects. The 4th gen V6 has the same center differential, so nothing will be damaged if you use it on dry pavement. The parts are basically identical to the V8, but there is a 2WD mode in the transfer case and an Automatic Differential Disconnect (ADD) up front. Just don't lock the center differential on dry pavement. The 5th gen (except Limited trim) has no center differential, so it would be bad to leave that in 4WD all the time.
Ah, ok, so I was just plain ignorant. Sorry, carry on.
Donated to SoulDog Rescue - '07 Limited 4.7 4WD | Toytec Boss kit front and rear set to 2.0" in front with standard Superflex 2" lift rear coils | Firestone 9" airbags | 600W Samlex PSW inverter | Slyfox SAIP bypass | Toytec 14" rear brakelines
'08 Limited 4.7 4WD | Toytec BOSS kit front and rear set to 2.75" front standard Superflex 2" lift rear coils | SPC balljoint UCA's | Firestone 9" airbags | Slyfox SAIP bypass | Toytec 14" rear brakelines
12-07-2016, 09:32 PM
#144
CV boots are rubber, treat them like any rubber. I use a good soak of Aerospace 303 on them monthly when I condition the leather. Same thing with the rubber hoses under the hood, the steering boots, door and window seals.
12-07-2016, 11:34 PM
#145
Real Name: James
Real Name: James
I've used spray silicone for such applications, not sure which is better.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
12-08-2016, 01:25 AM
#146
Real Name: Matt
Real Name: Matt
I think one of the two OEM CV boots on each axle is actually a special polymer. I can't remember the name. The other one is rubber.
2007 V8 Limited 4WD
01-11-2017, 04:19 AM
#147
Totally love my '06 Sport with the V8. Love the sound and acceleration (good for a truck) and the V8 is specifically why I bought it. Found a 1 owner with 59,000 miles, just purchase a month ago.
Handgun World Podcast
Owner of 2006, SR5 Sport Edition, V8 (59,000 miles purchased 12-23-16)
02-13-2017, 04:56 PM
#148
Sorry if this has been answered already but I couldn't find it.
How can you tell if a V8 is 4wd from ad listing pictures? Some people don't seem to know what they have.
Do they have the selectable knob to the right of the steering column like the V6s have?
2000 SR5
02-13-2017, 05:06 PM
#149
Yes, the selectable knob as well as "4wd" as part of the side badges. Such as "Limited 4WD" instead of just "Limited"
02-14-2017, 01:00 AM
#150
Real Name: Melinda
Real Name: Melinda
I'm fairly certain that all V8's are statistically AWD, so thus in 4 WD at all times. The selector turning knob to the right of the steering column only allows you to turn it to 4 Low. This is also why the V8 comes with the nicer Torsen transmission that has it's own brain box matched to it.
2003 Limited w/ Nav.; Painted custom; hood, bumpers, bottoms of doors, running boards, tail gate fin & bottom of gate, and roof racks lined with Full Metal Jacket polymer spray & repainted Trail Edition Shoreline Blue Pearl. De-badged since she's custom looking now. 4x4 V8. 320,000 miles as of Oct 2021. Mods: Fully synthetic fluids for engine oil & diffs. BFG A/T TA's KO2 for my TRD flat black rims & complete Stage 7 ICON suspension. A little front bumper plastic surgery. AFE Air filter. Magnaflow cat back exhaust. EBC green stuff brakes & slotted & drilled rotors.
