12-06-2016, 11:42 AM
#121
Real Name: Matt
Real Name: Matt
Originally Posted by flipflopnfly
You cannot leave a V6 in 4HI all the time on dry pavement, there will be ill effects.
There are no ill effects. The 4th gen V6 has the same center differential, so nothing will be damaged if you use it on dry pavement. The parts are basically identical to the V8, but there is a 2WD mode in the transfer case and an Automatic Differential Disconnect (ADD) up front. Just don't lock the center differential on dry pavement. The 5th gen (except Limited trim) has no center differential, so it would be bad to leave that in 4WD all the time.
2007 V8 Limited 4WD
12-06-2016, 12:43 PM
#122
AWD is great on the 120. Seriously.
12-06-2016, 01:56 PM
#123
Why would you ever want to leave it in 4hi that is the main reason not to buy the V8. Who the hell wants to drive around in awd all the time go buy a subaru. Also the towing difference is barely noticeable if you need to tow that much go buy a vehicle that was meant for towing. So basically all the v8 gives you is a marginal amount more power which is then taken away by being in awd all the time, worse gas mileage and oh yeah a nice $1000 gift every 80,000 miles.
2006 4runner sport v6 4x4, 1988 toyota pickup 22re m/t 4x4, 1979 f-150 429cj m/t 4x4, 1981 f-350 reg. cab shortbed twin turbo cummins 12 valve m/t 4x4, 1976 Unimog 406 case model, lots of old british motorcycles.
12-06-2016, 02:13 PM
#124
I look at it this way....a Hand Job (V6) and a Blow Job (V8) both achieve the same result. BUT one feels so much better!
12-06-2016, 02:48 PM
#125
Real Name: Chris
Real Name: Chris
I love my V8 AWD, wouldn't change it.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
12-06-2016, 11:55 PM
#126
Love my v8.
2006 Limited V8 4x4. Shadow Mica. FN fx pro wheels. bfg ko2 265/70/17 load range C.
Full album
12-06-2016, 11:58 PM
#127
I agree, I love my V8 AWD and wont change it. From my research the gas mileage difference is only 1 miles / gal so next to nothing. I also love the AWD, its lot of traction - much different than 2wd.
2005 T4R Silver, Limited, V8, Nav, Bil 5100, 1.5" front lift, Man-fre skid, Secondary Air Pump bypass
12-07-2016, 12:32 AM
#128
Real Name: Tony
Real Name: Tony
I'll line my V8 runner with 35's and stock gears up against your V6 any day of the week! You can then try to tell me how it is "marginally" more powerful. lol
You do NOT lose any power in AWD, and actually after driving around for a week without the front driveshaft I can tell you that in 2WD you can hardly get it to hook up. Awesome burnouts/donuts at will though! As for mileage, stock it does great. I consistently got 19mpg, which is great for a 5000lb box on wheels. Lets see what mileage the V6 gets with 35's .... The same or worse, especially since it's working way harder to do anything and everything. The timing belt I'll give you, it's annoying and retarded, but there is a huge difference that numbers on a piece of paper just can't show you. As for AWD only, well get an FJ cruiser t-case, bolts right in, then you have 2WD for day to day life.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
12-07-2016, 11:00 AM
#129
Real Name: James
Real Name: James
Will say that for my first mileage check, on a trip across the State, I got 19 going and 20 coming, driving on the e-way at 68 mph. Faster, I would expect to be much less, and this with the V-6 in 2wd.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
12-07-2016, 11:26 AM
#130
Real Name: Tony
Real Name: Tony
Originally Posted by sport2004
Will say that for my first mileage check, on a trip across the State, I got 19 going and 20 coming, driving on the e-way at 68 mph. Faster, I would be expect to be much less, and this with the V-6 in 2wd.
Yup, at 60-70 mph long cruise I averaged the same. 70+ it dropped fast! City/highway combined I got 16. Nowadays with the big heavy tires and lift I average 13, and 80+ on the freeway nets me 8-9mpg! Lol.
Sent from the drivers seat of my 05 4runner.
12-07-2016, 12:56 PM
#131
This back and forth arguing is hilarious.
All I'll say is that I absolutely love driving my V8, brings a smile to my face every time.
2006 Limited V8 - 1.25" wheel spacers | 275/70/18 LT Falken A/T3W | Bilstein 5100s | OME 885 springs in front | FJ springs in rear | LED light bar | Rhino Rack X-Tray
12-07-2016, 01:19 PM
#132
Real Name: Tony
Real Name: Tony
The sound of dat V8 doh!
https://m.flickr.com/photos/132186222@N08/30665102013/
12-07-2016, 01:43 PM
#133
Real Name: James
Real Name: James
If yer getting mud on yer windshield you must be doing something right.
Regards, sport2004
12-07-2016, 01:49 PM
#134
Real Name: Derek
Real Name: Derek
I have had some wheel time in the GX470 and my v6 T4R.
The only thing I really liked about the V8 is that it really flattens the hills.
The V6 is constantly down shifting.
They really dont feel much different to me as far as get-up-and-go.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
12-07-2016, 02:17 PM
#135
Related question: Do the AWD v8's generally last as long as the v6's that run in 2wd, without major repairs? I mean the longevity of the driveline (t-case, differentials, etc). I had a 2000 2wd with 230,000 miles for a few months last year (all I could afford at the time), that needed the whole rear end replaced from worn diff gears, bearings, and u-joints. And it had never even been taken offroad. I ended up selling it instead of paying to fix it. I don't look forward to having to replace all of that mess on my 2003 AWD if it starts to go! I figure it sees a lot more wear and tear over the life of the vehicle compared to the v6 since it is constantly being used and stressed, even as a pavement princess. Of course this is all just conjecture, but has anyone seen a noticeable difference between the two, since people generally drive these trucks to very high mileage?
Of course the engines and main components can go forever on these trucks but when all of the expensive 4x4 parts start to go, I imagine maintaining these things gets very pricey.
2003 Sport Edition 4x4 V8 with 170k+. 3" spacer lift on Billsteins w/stock coils, SPC UCA's, rear Airlift bags, Flowmaster, 285/70/17 Falken Wildpeak AT3W on 17x9 Dick Cepek rims, LED Interior swap, grill-mounted light bar, Thule roof bars/bike racks with rear lights, Kenwood stereo with Sony speakers
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
