Old 03-02-2019, 12:05 PM #1
dannyg dannyg is offline
dannyg is on a distinguished road
Help: VSC/TRAC/ABS/BRAKE lights on plus loud, continuous alarm?
I have an 03 V8 with around 160,000 miles.
Was driving home as usual when those lights and a loud, continuous beep started.
I pulled over and turned everything off for a minute. When I restarted all of the lights and the alarm were still going.
I decided to finish my commute home (less than 10 mins, 25 mph streets). Everything seemed normal (except the obnoxious noise).
I got home, parked but then needed to move to another spot.
That time moving the vehicle I had to press VERY hard on the brakes, pedal almost went to the floor, to get it to stop (driveway speed). Brake fluid level is normal.
I'm hesitant to even drive down the street to get the vehicle scanned... any thoughts?
Oh, and as this seems brake related I should add that I have had warped rotors that need resurface/replacement for a while now. I have not gotten around to it because I was told the pads were fine and there was no real safety issue, just some not very smooth braking...
2003 Limited 4x4 v8
dannyg is offline   Reply With QuoteReply With Quote
Old 03-02-2019, 12:46 PM #2
KwonRunner's Avatar
KwonRunner KwonRunner is offline
KwonRunner is on a distinguished road
KwonRunner's Avatar
See if you can pull any codes by going to the local o'Reilly's. At worst, it could be the brake's hydroboost assembly. My 4runners is at the dealer getting that replaced. Pricey to fix.
2008 V6 Sport Edition 4wd
KwonRunner is offline   Reply With QuoteReply With Quote
Old 03-02-2019, 01:21 PM #3
I had the vehicle scanned at home (at this point I consider it non-drive-able, the brakes hardly work even pressed to the floor).
It did not throw any codes whatsoever....
2003 Limited 4x4 v8
Old 03-02-2019, 01:22 PM #4
Originally Posted by KwonRunner View Post
See if you can pull any codes by going to the local o'Reilly's. At worst, it could be the brake's hydroboost assembly. My 4runners is at the dealer getting mine replaced. Pricey to fix.
Were your symptoms the same as I described?
2003 Limited 4x4 v8
Old 03-02-2019, 02:49 PM #5
KwonRunner's Avatar
KwonRunner's Avatar
Good news is no. Just thought I'd share because it sounds like you might have brake problems. For me, my vsc off started flashing and my trac lights came on when I would go into h4 or l4. They stayed on going back into h2. The code that came up for me was c1340.
Old 03-02-2019, 03:30 PM #6
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
What you described are the classic symptoms of master cylinder failure.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 03-02-2019, 04:18 PM #7
Was hoping this was not the case...
In your opinion, is it worth the ~$100+ to have the dealer or a mechanic do a diagnostic to confirm the issue? Aka, could this actually be a 'cheaper' issue?
From what I have read it may be ~$3K+ to have it replaced
2003 Limited 4x4 v8
Old 03-02-2019, 07:17 PM #8
KwonRunner's Avatar
KwonRunner's Avatar
Yeah, seems so.
Toyota 4Runner Brake Master Cylinder May Need Replacing
Old 03-03-2019, 01:30 AM #9
New_2_4runners New_2_4runners is offline
New_2_4runners will become famous soon enough
Just buy a new brake accumulator and swap it out. That’s usually the fix.
2003-2005 Toyota 4Runner Brake Accumulator - Brake - Genuine 03-05 4Runner Brake Accumulator - 7926-01209962 - PartsGeek
New_2_4runners is offline   Reply With QuoteReply With Quote
Old 03-03-2019, 11:26 AM #10
azgold azgold is offline
azgold is on a distinguished road
Do not panic. Yes the hydraulic brake booster assembly is very expensive, however you may be able to figure out what specific part in the booster assembly is failing. Some of those specific parts are available through the dealer.
If you have to replace the whole assembly you can purchase them through dealers on line for nearly half the cost of what the local dealer will charge you . If you are a little mechanically inclined, installing it yourself should not be an issue. After an install though, you may consider bringing it to the dealer and have them bleed the system of air.
azgold is offline   Reply With QuoteReply With Quote
Old 03-03-2019, 01:37 PM #11
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
Turn the key to on the on position, don't start the truck, have someone pump the brakes.
Open the hood and listen for the electric motor on the bottom of the brake booster. It's under the brake fluid reservoir, the black cylindrical thing.
If the motor is not running, that's your problem. Remove the motor. Get it rebuilt for like 200 bucks at any place that rebuilds electrical motors.
If the motor is running constantly, its the accumulator that is bad. Buy a new one on eBay for around $250...
Had a local mechanic replace both of these parts, charged me 2 hours worth of labor...
Really the motor and accumulator are the only 2 parts of the brake booster that go bad, please don't spend the 3 grand the dealer chargers to replace the whole assembly
Edit: Adding some part numbers that might be helpful.
The accumulator is Toyota Part No.: 47950-30010. If this is bad you also need a new O-Ring gasket for it which is Toyota Part No.: 90301-13014
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 03-03-2019, 01:44 PM #12
^^this!
Old 03-03-2019, 09:56 PM #13
Thank you, this is really helpful, I will have to try it out!
So just an update, I did have it towed to the local dealership. They ran a diagnostic ($69), said I needed a new master cylinder assembly and was quoted $3900 for parts and service!
I actually started looking at new car options and test drove a 2019, was only offered $1000 and eventually $2000 trade in value..
I still need time to make a decision, my 4r is still sitting at the service center... but knowing the repair could be a fraction of what I was quoted definitely changes things as well. Thanks again!
2003 Limited 4x4 v8
Old 03-05-2019, 06:35 AM #14
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
either replace the accumulator or consider buying a used unit off ebay, goes for $350 to $700
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 09:37 AM #15
Yes! That is now the plan, I just need to get to the stealership to confirm the issue how 4runnerMexico described.
I called a local shop who said they would replace the accumulator or whole assembly for around 3 hrs labor ~$400, I provide the parts.
Also, is it possible to drive the vehicle in its current condition?
2003 Limited 4x4 v8
brake , home , lights , normal , vehicle
ABS/VSC TRAC/Brake Lights and Audible Alarm T4Rfirefighter 3rd gen T4Rs 11 10-30-2017 03:31 PM
ABS, VSC Trac, and Brake idiot lights on, audible alarm. What gives? Kardolf 4th Gen T4Rs 5 09-11-2015 02:48 PM
VSC Trac light + continuous beep Laotian Commotion 4th Gen T4Rs 1 10-08-2014 12:50 AM
'check engine', 'trac off', and 'vsc' lights came on. Plus 'abs' and 'brake' lights thehadley4 3rd gen T4Rs 0 10-23-2011 01:51 PM
VSC TRAC, TRAC OFF, ABS and BRAKE lights ENRIQUE Problems & Warranty Issues 3 02-03-2011 10:57 PM
