08-07-2013, 05:01 PM
#16
Originally Posted by BOSMECH
I am glad that you said that because this is driving me nuts, how much was the cap from Toyota.
I bought an OEM cap off amazon for $15-20.
I initially blamed my wife for not tightening it properly when she filled up. Then it did it to me. I never told her I replaced the cap... LOL.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
08-07-2013, 05:56 PM
#17
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
Good recovery.
2003 SR5 V6 4WD Stock (totaled)
2005 Sport Edition SR5 V6 4WD
12-27-2018, 08:55 PM
#18
in the same boat, long tern fuel trims high 35%, p0174 code. cleaned maf+TB, no change.02 sensor reading are ok from the scan tool. really stumped!
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
03-05-2019, 06:33 AM
#19
bought a fuel pressure kit and fuel cap from amazon, will check my fuel supply pressure and try to eliminate possible causes
03-05-2019, 07:51 AM
#20
Hopefully it’s as simple as the cap! Unfortunately, I’ve never been that lucky when it comes to CELs...
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
05-03-2019, 02:25 AM
#21
I just got the P0174 and I think it is the gas cap since I checked everything else and the O2 sensors are all good and it only happens after my wife fills up the tank, and she does make sure the cap is tight but it comes loose real easy.
so this was a permanent solution?, replacing the gas cap. i have a stubborn p0174 and its driving me nuts
05-05-2019, 09:45 PM
#22
Gas Cap?
I got the P0174 code. It's come on and gone off a couple of times. Usually comes on after I have to do a fast acceleration (which with 186K miles isn't all that fast anymore). I recently filled up and the light went off which makes me think it is the gas cap, though I haven't noticed any deterioration.
05-08-2019, 03:39 AM
#23
That is what mine was. The o-ring on the cap had deteriorated and it wasn't holding the proper pressure in the tank. Almost as if the cap was not clicked when I put it on. New cap solved the problem.
still dont understand how a bad gas cap will only affect bank 2, hence the p0174, i was thinking it should affect both banks, hence it would throw a p0171 code as well
@ BOSMECH
, so seems you changed your o2 sensors and it didnt resolve the problem?, ,......what did the gas cap change?
12-10-2019, 11:07 PM
#24
@ BOSMECH
Did you ever get this figured out? chasing bank 2 lean codes. they keep changing. p0158, p0174, p2197
12-12-2019, 12:28 AM
#25
Yup i did.
My fuel trims got worse.upto 39% for bank 2 and 20% for bank 1 and occasinal p171 &p0430
I bought remanned injectors off ebay for 59 bucks and swapped. All codes went away and my fuel trims are great now, abt -2 or so..
See pic of old vs new injectors
12-12-2019, 01:57 AM
#26
Yup i did.
Thanks for the reply. Mine was a little more weird, that I think I narrowed down.
Just recently bought a 2006 v8 4wd with a blown engine to compliment my supercharged 03. Installed the engine, fixed the MAF connector, and the codes started. So today, I swapped the upstream o2 banks and the code followed. So I installed the denso replacement and I got from amazon, and the code was still there. Swapped the new one back to the original troubled bank, and the code followed back. Only conclusion is that it is DOA and I actually think it’s counterfeit because the box is a different color and looks cheaply printed compared to the downstream denso replacement box
12-13-2019, 01:49 PM
#27
Posting my solution, in case it helps anybody in the future: After trying 2 new sensors and seeing that the code was following the bank, I decided to replace both upstream sensors. I cleared the codes one more time, and it now seems that the code is gone for now, for good. LTFT are perfect on both banks. It seems that the ECU wants to see the both side replaced at the same time, as probably a good old sensor vs a good new sensor has too large of a voltage or resistance discrepancy. It likely compares both banks to throw the code.
Now, all is good. I did use 2 Denso amazon replacements. This Harbor Freight Wrench set is probably the easiest way to get these off. Makes it a 5 minute job on each side with a cold engine.
Metric Double-End Flare Nut Wrench Set, 5 Pc.
