Originally Posted by Mytoy4
I didn't have too much trouble doing it. That wooden template helped a great deal. Sorry you're having a tough time with it.
Hopefully you'll find in the end that it was worth it. I'd love to see when you're all done.
Well your write up helps significantly. I made the wood jig, shaped up the mesh, no problem. It was fitting the mesh inside the grill that turned out amateur. I'm going to try and adjust the jig to reduce the mesh material and try again.
Also, I'm using a different mesh pattern. Smaller diamond shape that may be a little harder to shape than the mesh referenced in this write up.
I'll post pics once I'm satisfied.
