01-07-2020, 04:09 PM
#1261
Real Name: Sam
Real Name: Sam
01-07-2020, 04:16 PM
#1262
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Looks like a good match to me....
01-07-2020, 04:31 PM
#1263
Real Name: Todd
Real Name: Todd
Originally Posted by LTDSC
Where did you source the cover from? I need to do both front seats in my '03.
01-07-2020, 04:45 PM
#1264
Real Name: Sam
Real Name: Sam
snagged it off ebay awhile back and just never got around to swapping it. Im real happy with the quality. I bought it from the seller usautonation
01-30-2020, 11:21 AM
#1265
Hey I bought a +2 TC kit, scratch and dent for a good price, and was wanting to swap to heim UCA's, if that would gain me additional caster.
I noticed you have solid alignment plates instead of the cams on your LCAs and wondered if that was part of the TC kit or if you picked it up somewhere else?
I might try to contact TC to see if they will swap out the UCAs if I pay the difference. Worth a shot. Or jig them and build my own.
01-30-2020, 11:56 AM
#1266
Just curious if you could shed some details on how you have it hooked up and have it wired? Can't see the images.
Added solar panels to the roof to help keep my battery topped off since its not my daily as well as help with power while im out camping and using the fridge. I had a Renogy solar suitcase already that i deconstructed and made into a mountable solution. 100w combined system with a 20a waterproof controller.
I attempted originally to have the panels below and/or flush with the rack bars but the arch of my roof prevented that. I have since painted the brackets black to blend in more.
01-30-2020, 12:57 PM
#1267
Real Name: Sam
Real Name: Sam
I purchased the solid mounted cam tab plates from Poly Performance.
Poly Performance Tab Alignment Cam Delete Kit for Toyota 05-15 Tacoma, 03-09 4Runner, GX470, 07-09 FJ Cruiser | POLY PERFORMANCE
it absolutely helped with even more caster with the LCA maxed position and then adjusting the upper heims properly. Now i only have to worry about the toe getting knocked out of alignment.
Cant see the images? hmm thats odd.
I used the Renogy solar kit
Amazon.com : Renogy 100 Watts 12 Volts Monocrystalline Solar Starter Kit : Garden & Outdoor
The wires from the panel connect to the solar charger, then there are wires from the connector to the battery terminals. It charges until full then just maintains. Its been a huge help since i dont drive my 4runner daily anymore and when im off the grid and lights and fridge are working when im camping.
01-30-2020, 01:35 PM
#1268
@ LTDSC
let me know if you have any buddies that want to split the cost of +2 long travel axle shafts so we can both have a spare CV built and ready to swap.
Or if you know of anybody with a spare already that I can buy off them.
Might be worth bothering TC with another email to see if they will just sell me 1.
01-30-2020, 01:36 PM
#1269
Awesome, thanks for the info!
01-30-2020, 03:26 PM
#1270
Real Name: Sam
Real Name: Sam
@ LTDSC
i have a spare +2 shaft already built in my garage. I obviously cant use it now lol
01-30-2020, 03:30 PM
#1271
I love you.
PM me your price.
02-10-2020, 07:54 PM
#1272
I have been going through your build thread (great thread btw) and was wondering why did you not go for the ball joint with the zerk fitting so it is greaseable? Do the links make any noise at all?
McMaster-Carr has part# 4444T21 for example that is the same exact as the one listed below, but with the fitting. The only difference I see is static load capacity is a bit less with the greaseable part (5100 vs 6300 lbs).
Also, I might have missed it, but what did you do for the fronts? Did you keep them stock, build out a longer heavier duty set, or do you just disconnect when on the trails?
Ok heres the parts list and my installation information/pics
I took this parts list from Toyota120 so ill copy and paste what i used.
Energy Suspension kit (Part #9.8121R) which I got off amazon.
McMaster-Carr
Qty 1. ASTM A193 Grade B7 Alloy Steel Threaded Rod, Plain Finish, 3/8"-24 Thread, 2' Length; Part number 98957A805
Qty 2. Steel Ball Joint Rod End, 3/8"-24 Right-Hand Female Shank, 3/8" Ball ID, 13/16" L Thread; Part number 60645K341
Qty 2. Zinc-Plated Steel Washer for Ball Joint Rod End, Fits 3/8" Shank Size; Part number 95034A300
Lowes
Qty 2. Grade 8 3/8" 2" length bolts
Qty 2. Grade 8 3/8"-24 Thread nylock nuts
Qty 2. Grade 8 3/8"-16 Thread nylock nuts
Qty 2. Packs of 3/8" grade 8 washers
Qty 2. 3/8x1/2x1-1/2" Steel Spacer
Red Loctite
Stock comparison
Very easy installation and build, i highly recommend them. Im only in this about $40.
-2007 Sport Edition 4Runner V8
02-11-2020, 03:09 PM
#1273
Real Name: Sam
Real Name: Sam
havent had any noises from them that i can tell anyway.
Front sway bar is removed completely.
02-17-2020, 11:32 AM
#1274
I can see the pictures now, lol.
Just trying to get more info on the hookup of the solar charger. Where did you put the solar charger at in the 4runner? Were you able to route the wires to the inside somehow? I'm assuming there are cables from the solar kit to hook the battery to the charger?
Appreciate it!
02-17-2020, 11:38 AM
#1275
Real Name: Sam
Real Name: Sam
Appreciate it!
The solar install is fairly easy. I mounted the waterproof solar controller in the engine bay, adjacent to the power steering fluid reservoir on the fender apron there.
Wires from the solar panels come down the windshield trim which i siliconed in place and its hidden. Under the cowl and down the fender apron to the controller. Then from the controller across the radiator area to the battery. Hidden as well under the plastic covers.
