Originally Posted by Joey805
When it's on defrost, it should only be blowing on the front window.
The way the system is designed, is if the defoster is on, your side vents next to the front windows will be on to keep the front side windows clear so you can use your outside mirrors. The vents in front (either side of the radio) should not having much air. A little might escape, but it shouldn't be much.
Edit: TechWrench beat me to it!
If you are having problems with your blend doors, try changing the HVAC controls.
