Old 12-26-2012, 11:34 AM #1
mountainfreak mountainfreak is offline
mountainfreak is on a distinguished road
Towing capacity
Hey everybody,
I'm looking to buy an airstream type trailer to tow behind my 2005 v8 4runner sport. I think Toyota lists the towing capacity somewhere in the 4000LB range. The Airstream Bambi is just under 4000LBs but I have heard some discussion that the 4runners true towing capacity may be less than advertised. Does anyone out there have any experience with this? Thanks.
mountainfreak is offline   Reply With QuoteReply With Quote
Old 12-26-2012, 11:38 AM #2
aha2988's Avatar
aha2988 aha2988 is offline
Real Name: Austin
aha2988 will become famous soon enough aha2988 will become famous soon enough
aha2988's Avatar
Real Name: Austin
your V8 should have a tow rating of 7000lbs (4wd) the 2wd V8's have a 7200lbs capacity. (there was a hitch controversy in the 03 models and some 04's) but by the 05's they had the proper hitch to back there towing capacities.
you'll have no problems toting that 4000lb trailer
-Austin
A-Ha's Build
aha2988 is offline   Reply With QuoteReply With Quote
Old 12-26-2012, 12:51 PM #3
2007toyota4runners's Avatar
2007toyota4runners 2007toyota4runners is offline
Real Name: Maharshee Patel
2007toyota4runners is on a distinguished road
V8+weight distributing hitch=7000lb
V6+weight carrying hitch=5000lb
2014 4runner Limited Attitude Black Metallic 55W 5000K TheRetrofitSource Morimoto HID
2006 Subraru WRX Limited STI swapped and fully built
2007 4runner SR5 4WD V6 55w 4300K Morimoto Xenons, Morimoto 90mm Halo's, Blacked out trim, Plasti Dipped Wheels, Nitto Terra Grapplers 265/70/17(R.I.P)
2008 Nissan Sentra SER Spec-V (Sold)
2007toyota4runners is offline   Reply With QuoteReply With Quote
Old 12-26-2012, 08:59 PM #4
jdkilroy's Avatar
jdkilroy jdkilroy is offline
Real Name: Jon
jdkilroy is on a distinguished road
jdkilroy's Avatar
Real Name: Jon
Towing capacity does not appear to be an issue with the trailer you are specifying however...
The 4Runner has a pretty short wheelbase compared to say a full sized pick-up. What you may discover is that you end up with a tail wagging the dog situation with the trailer causing the vehicle to oscillate above certain speeds.
Something to keep in mind and look for.
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
jdkilroy is offline   Reply With QuoteReply With Quote
Old 12-26-2012, 09:05 PM #5
cacarbuff cacarbuff is offline
cacarbuff is on a distinguished road
We have an 05 v8 4runner and tow a 22ft box trailer loaded to about 5500lbs all over the place. This summer we actually did a 3000mi roadtrip with this setup with no problems whatsoever.
The tongue weight of our trailer was a bit heavy though, so we invested in an EazLift weight distribution hitch and swaybar system that made the towing a bit more comfortable and with less sag
You should have no problem with the airstream. Let me know if you have any questions about our setup.
cacarbuff is offline   Reply With QuoteReply With Quote
V6 vs V8 Towing Capacity jkruer01 4th Gen T4Rs 73 09-28-2021 04:16 PM
Towing capacity robertxge New Members 1 10-06-2010 02:13 PM
towing capacity gilligan79 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 03-28-2008 07:11 PM
Towing Capacity GTOto4R 3rd gen T4Rs 1 05-02-2006 05:20 PM
towing capacity TJhilux 3rd gen T4Rs 8 02-16-2005 01:49 AM
