01-04-2013, 12:00 AM
Spacer Lifts
With my 2003 SR5, I'm interested in a spacer lift, like a Cornfed 3"/2" leveling kit. It looks pretty simple from what I can tell, as far as components. Am I correct that other than the spacer components and hardware, everything else can remain as it is, e.g. shocks, springs, etc?
Also, how do spacer lifts affect towing ability and capacity?
Thanks
1996 T4R SR5 4WD RED, Goodyear A/Ts, Moog springs - SOLD
1989 T4R SR5 4WD 4 Cyl. 5 Speed Soft Top - SOLD
2003 T4R SR5 4WD V8: Toytec Ultimate Lift w/ Bilstein 5100s, Curt Roof Rack, HCF delete, MB 16x8.5 Rims, 285/75r16 ATs
01-04-2013, 12:15 AM
Real Name: Ethan
Real Name: Ethan
spacer lifts are super simple to understand and install, counting in my head you need to remove a total of 6 bolts in the front and about 2 or 3 in the rear in order to install topout only spacer lifts. the cornfed 3/2 has a preload front, so strut disassembly is required, a little more involved. as far as towing and capacity, i havent ever heard of any negative affects to either from running a spacer lift, but others on the forum may know more on the subject than i.
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555
oh my god the erection I have from this thread is unreal.
01-04-2013, 05:36 PM
You should find all your answers in the FAQ section. 4th Gen Suspension Options/FAQ
01-04-2013, 08:23 PM
Real Name: Leonard
Real Name: Leonard
Pretty easy install if you have the tools, as far as towing, all is the same. The feel is the same as you have the same spring as before as your used to, just need to change the lift/drop size of the hitch to level your trailer load.
01-05-2013, 12:32 AM
The FAQ basically said that there's three types of spacer lifts. Which is the most durable and which is the easiest to install? Also, I'm replacing shocks and struts - would a lot of this disassembly needed for the spacer lift be underway with the shock/strut work? That way, I'd kill two birds with one stone.
01-05-2013, 01:45 AM
Real Name: Leonard
Real Name: Leonard
The spacer lift comes with all you need, the front has a spacer with instructions and will work with your factory strut. The rear spacer rides over your coil and comes with a longer shock for the incress height.
So, all you should would be a new strut if you wish.
Tools, pickel fork, spring compresser, sockets, jacks and stands.
01-05-2013, 01:52 AM
Since you stated you're replacing the shocks/springs why don't you just go with an OME shock/spring setup and skip the spacers all together. Have a better suspension, get your lift, and smile.
| ICON 2.5 | XD ADDICTS | DURATRAC 33" | CAMBURG UCA's |
01-05-2013, 01:58 AM
It would be a better option but I'm short on money. Unless there's an unknown option to me (I'm sure there is) that I should pursue. Any suggestions?
01-05-2013, 02:56 AM
Check the classifieds. I see used quality suspension setups in there for cheap all the time.
01-05-2013, 10:46 AM
Real Name: Jesse
Real Name: Jesse
This
_____________________________________________
2016 Trail-P Dobinsons 302/325 DK Chromoly, 285 kO2, C4, RCI, BD Squad Sport, XD Phillips HID's, Tint, Husky liners, Crestone Rack
2020 Gx460
2000 Limited 4X4 - OME 881/890- B&M 70264
Overland Bound #10926
01-06-2013, 01:11 PM
So an OME setup is just new shocks struts and springs that lift the car? How much would one of those run me new? How about used?
01-06-2013, 01:54 PM
I have been very happy with my Cornfed 3/2 lift. I hated the stock low sitting look and if you will be using your truck for primarily street driving then I think that this is the best way to go. Check out my garage for pics.
2003 4Runner Limited V8 4WD;Pacific Blue Metallic; Cornfed 3/2 Lift; Spidertrax Wheel Spacers;Magnaflow Cat-Back Exhaust; Nitto Terra Grapplers 265/70/17; aFe Pro-Dry S Air Filter; Philips 4300 Xtreme HID Low-Beams; PIAA 540 Plasma Ion Fogs; HIR Hi-Beams; HIR main fogs; Man-A-Fre Front Skid; Alpine Head Unit w/I-pod Interface; Alpine Type-R 10" Sub; Kenwood 1000W Amp; JBL 10 speaker system; Steelcraft Bull Bar; Go Rhino Hitch Step; PIAA Super Silicone Wipers; TRD Radiator and Oil Caps; Brembo brake pads & rotors; TRD Carbon Fiber and iForceV8 Emblems on Hatch; all LED interior, Running Board, Reverse and License Plate bulb replacements; Weather Tech mats and Cargo Liner; Blitz Hybrid Cabin A/C Filter
