Real Name: Patrick
Real Name: Patrick
From Spacer to Spring/Coil
HI,
I've been looking at the lift threads and can't seem to decide what to do. I currently hace 2.5/1.5 daystar with new 265/65/18 BFG. I like a lift that i basically the same as the spacers i have maybe a bit larger because i don't want to have to get new tires.
Please i've been searching the threads and don't know which lift to get. Should i get the OME front andf toy tech rear springs with bilstein shocks? I really don't want wheel spacers if i don't need to get them.
I don't want icons because they require maintenance.
Any input appreciated. I really want around a 2.5" lift. I don't want to go to high. Also, currently a hidden winch system for 4th gen in under production which i plan to install!
Thanks for the input
2007 Limited V8, AWD, Pelican Storage Cases, Radflo 2.5 Kit. Metal Tech Rear Offset Lower Links. 265/65/18 BFG TKO. Redline Full Synthetic lube, ARB Deluxe Bull Bar and SLEE ARB Foglight Light Surround with Rigid D2 Fogs and ARB LED Indicator/Markers. WARN 9.5XP. Dirty Parts Dual Battery Kit w/ rocker switch & Dual AGM Batteries. Gobi Stealth Roof Rack, ladder, Sunroof Insert, and Tool Box Stealth. ARB Diff breather kit.. (2) ARB Quick connect for jumpers and rear voltage access. Projecta Dual Battery voltage monitor. AGM Voltage Booster PRO “Texas Slim”.
