01-18-2013, 03:02 AM
What do you gap your plugs at? I changed my oil, plugs and air filter and lost mpg
Hey -
I bought my 09 limited with 58,000 miles so at 60k I put in new NGK Iridums (dont remember the model, I got it off this site though) that came pre-gapped to .41-.42
My last 3 tanks on the new plugs my MPG has gone down 60 miles per tank....
Im thinking it has to be the gap. What do you gap at?
01-18-2013, 03:28 AM
First off is it a V6 or V8? I also believe that information can be found in the Owner's Manual if I remember correctly.
I can't remember what the gap is for both engines off the top of my head though.
01-18-2013, 04:39 AM
most are pre gapped at .44, make sure to check each plug, i gap my denso at .39
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
01-18-2013, 06:02 AM
According to the Toyota manual you do not adjust the gap. They are already pregapped so just install them.
2009 Trail Edition - ICON lift, Total Chaos UCA, BF Goodrich Mud Terrain KM2 285/70/17's, SCS Stealth 6 Matte Gunmetal finish, K9 2.2m Roof Rack.
01-18-2013, 08:19 AM
At that mileage, maybe try cleaning the MAF (Mass Air Flow) sensor.
By the work one knows the worker. --fortune cookie.
01-18-2013, 08:55 AM
I've bought toyota plugs online and at dealer, some were definitely not gapped correctly, others were spot-on.
I've used the gaps spec in the manual, seems to be fine, no change to MPG.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
01-18-2013, 09:34 AM
Real Name: Kris
Real Name: Kris
Yup!! There will be a few that are not gapped correctly so you need to make sure they are. I just changed mine last month and all are gapped @.41 and I used all Denso from the dealer. No effect in gas mileage.
2016 Trail Edition Premium
KF5UXO
01-18-2013, 10:09 AM
That would be the first manual I've ever seen that said NOT to check the gap of plugs before you install them.
Plugs are regapped at the factory...but things happen during shipping. My last tuneup I did...2 of the 6 plugs were off a little.
01-18-2013, 10:50 AM
Real Name: Jesse
Real Name: Jesse
My mileage didn't change after i installed new plugs @ 60k miles. I bought plugs from the dealer and checked gap, they were fine out of the box. My gas light comes on at 370 miles.
_____________________________________________
2016 Trail-P Dobinsons 302/325 DK Chromoly, 285 kO2, C4, RCI, BD Squad Sport, XD Phillips HID's, Tint, Husky liners, Crestone Rack
2020 Gx460
2000 Limited 4X4 - OME 881/890- B&M 70264
Overland Bound #10926
01-18-2013, 11:23 AM
It's a V6 but I dont have a manual.
01-18-2013, 12:13 PM
Originally Posted by jizzam93
Yup!! There will be a few that are not gapped correctly so you need to make sure they are. I just changed mine last month and all are gapped @.39 and I used all Denso from the dealer. No effect in gas mileage.
Why do you gap smaller than what is spec? Just curious.
2004 SR5, V-8, 6000k HID in headlights and Fogs, HCF MIA, K&N drop in, Rear Cat Convertor missing, MagnaFlow muffler, ToyTec Ultimate, Light Racing UCAs, SpiderTrax, 255/85R16 Cooper St, AVIC-X930BT, XM Satellite and HAM Radio. Otherwise completely stock.....For now. This pulls one HELL of a homebuilt camping trailer! Details to come!
01-18-2013, 12:23 PM
This is what they came gapped at, I didnt change them. I had read a few threads on here that they came pre-gapped and that .41 was about right. I checked them and they were all right around .41-.43 so I popped them in.
The older ones were gapped a little wider, I just didnt think it would effect MPG that much. Im getting ~340-350 per tank now.
Think I should pull them out and regap them to .44?
01-18-2013, 02:21 PM
Real Name: Kris
Real Name: Kris
Fixed. I was reading the post above me and for some reason I put the wrong gap. Good catch and sorry bout that.
My taco had the same engine and it was indeed .41.
KF5UXO
01-19-2013, 02:03 AM
This is absolutely true, always double check the gap on plugs because they can get dropped, dinged, ect and the gap changed. Sometimes they even get misadjusted from the factory.
01-19-2013, 03:02 AM
I always suggest checking the gap as well. I have seen some really really bad units go into vehicles because someone down the road dropped it and it landed just right to change the gap. I see a lot of boxed plugs come with the cardboard unit on them but they might have been bumped between here and there
Looking around I see the gap for most plugs is preset at .044. I haven't been able to get a service manual without it being a zip file so when I get it unzipped I will find out if I am right or wrong lol
