01-19-2013, 09:26 PM
#16
Also interested to see what you did with the hood latch
01-19-2013, 11:50 PM
#17
That looks great man!!!! I was considering installing my light bar inside my stock bull bar, but I might have to try this out!!!
I've been looking all over the the mesh grille, do you recommend any brand?
Thanks in advance
01-20-2013, 01:20 PM
#18
Thanks in advance
The grille is called a "satoshi" mod, its fully customized
01-20-2013, 02:36 PM
#19
Looks great...might even be room for one more behind that grille
Hows the light output?
SOLD Jan/15
03 V8 4x4 Limited, RAS converted to coil w/1.5 spacers, Bilstein 5100's 2.5" setting, 265/70R17 Grabber AT2s, FJ Rims, Custom headers, dual exhaust, 20% tint, HCF delete, VSC off mod, blacked-out headlights, WeatherTechs, TRD shift knob.
01-21-2013, 03:06 PM
#20
Originally Posted by YotaDriver
Do you think your engine might run hotter with the light bar somewhat restricting the airflow to the radiator?
With the satoshi it should get more air flow than stock anyway so I don't think it's an issue.
2005 Sport, 3" OME, 1.5" RB Body - Build Thread
01-21-2013, 03:11 PM
#21
Originally Posted by seevik
Looks great, this is what I want to do as well. I like the idea of the mounts s well. What did you do to smoke the glass? And did you lose any light output?
Home Depot sells a smoked plexiglass. I bought a sheet and cut it with a razor and straight edge to size then used a strip of black tape and zip ties for now. I wanted it to make sure it was removable easily on the trail.
As far as light output, I'm sure it reduced it by at least 10% but it is worth it for the overall look and I can take it off if I need.
01-21-2013, 03:14 PM
#22
It is a custom piece of wire I used when I did the 2006+ facelift. I installed the light bar far enough back that it doesn't touch. The rear of the light almost touches the horns and radiator tubing.
03-18-2013, 06:48 PM
#23
Originally Posted by fedrlbiker
Double post from my build thread to make it more search friendly.
I finally got it all worked out to hide my light bar behind the satoshi grill. I love the stealth look! The mount is kinda ghetto, but it's all I could come up with to get it in the right spot.
Also, the lens it held on by a strip of electrical tape up top and 3 zip ties. One at each end and one in the middle. That way I can remove it if I ever need just a little more light output and put it back on later.
The mount
Before the smoked lens
After the smoked lens
Let there be light!
looks real good with the smoked lens'.... those grill would look better without the toyota imo..
2007 Driftwood Pearl SR5 V6 4x4 /MB Wheels TKO 17x8.5 -6mm/ Hankook dynapro mt2 285/70/17 / bilstein 5100s -1.5 daystar rear spacer lift on moog fj coils / 1" Toytec body lift / ddm hids / interior leds / reverse light led / vsc - atrac disable mod / limo-30% tint/ rear diff breather mod / rola vortex roof rack / hanma 30" LED lightbar / kenwood ddx373bt w backup camera / ppi p900.4 / sundown sax1200d sa8d4v1.5 / diamond audio d6 comps / SPPC black halos
03-18-2013, 07:01 PM
#24
Want to see night pics!!!!! That looks good!
E-Locker, Bilstein 5100,LX 450 Coils, Tundra Wheels Graphite, 33'' Duratracs, 1.5" wheel Spacers, Energy Suspension Sway Bar Links and bushings,Roll Bar, LED's, Sport Hood! XRC 9.5k Comp Winch Custom Mounted, 3rd Row Rumble Seat, B&M Tranny Cooler, Tundra Brakes, 4XInnovations Sliders, Uniden 520XL Pro CB, 4' Firestik.
My Build Thread!!
http://www.toyota-4runner.org/3rd-ge...8-limited.html
03-18-2013, 07:49 PM
#25
Schweet! Is that another light bar in the bumper cut out?
03-19-2013, 04:02 PM
#26
No, just a reflection on the camera lens.
03-25-2013, 02:03 PM
#27
Edit: Didn't read. Found it. Nevermind.
Where'd you get the smoked lens?
04-16-2015, 04:49 PM
#28
Looks great, did you have any issues on tuning and connecting the wires? Can you post on how to wire it to the battery and switch inside?
04-16-2015, 06:07 PM
#29
Real Name: Sang
Real Name: Sang
That is clean, great work!
2003 GX470 Ash Blue Mica "Bianca" Blue Steel 2.0
Demello front bumper, Icon 2.5 ext. travel coilovers w/ reservoirs, Icon VS2.0 rear shocks, Ironman rear conversion kit, Toytec Superflex rear coils, Black Rhino Roku wheels, 295 Toyo RT, Flowmaster Super 10, Inno Shadow 13, Tuff Stuff awning, LenzDesign snorkel, RRW sliders, Outrider lower link mount skids, Depo Sport head lights, Rago Fab ditch brackets, KC G34 LED pods
01-31-2017, 02:19 AM
#30
how big is the light bar?
