Originally Posted by Jackkill1
The spare tire is not lowering. The handle is turning freely when I crank it counter clock-wise. Either I don't have it seated in the slot of the cranking mechanism or I do and the mechanism is broke. Any thoughts? Thanks in advance.
the reason it is not dropping is the rod is not engaging into the crank .. the end of the rod is a bit too small and the tube a bit too big. so need to try inserting this rod several times until you feel a connection and rotation resistance..
I do this every november when I do the complete vehicle maintenance work ..
