01-23-2013, 10:08 PM
Fuel economy
Hello everyone..... i own a 2003 4runner, I feel my gas mileage is very low. i bought a new air filter and still doesnt go up 15.4 mpg.. Does anyone have any clue what could be wrong??? is v6 engine
01-23-2013, 10:22 PM
Fuel economy
How do u drive and in what conditions?
Also is your truck stock?
I have had mpg that low stock in lv w ac running all the time.
2005 4Runner SR5 V6, Factory 17s, Roof Rack, nerf bars, BFG A/Ts, Thule MOAB Basket, Thule Hull-A-Port, Thule Terrapin Cargo box, Ventshade Bugflector, Putco Window Visors, Alpin CDE 133BT w/ Alpine Amp, Kicker Solo-Baric L7 w/ Kicker mono amp, Optima Red Top, Yakima Doubledown Ace hitch rack, K&N Intake, TRD Exhaust, Amsoil Dual-Guard Bypass, Amsoil Synthetics throughout, Shrockworks Winch Bumper w/ PIAA 510 Fog & 580 Driving (being built now!)
01-23-2013, 10:25 PM
Reset the ecu.
Other than the air filter, what other maintnance have you done?
I also have a v6 and average about 17.5 mpg (calculated) for mixed driving.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
01-23-2013, 10:41 PM
i do like 80% to 90% city driving and i get around 16.2
also keep track of my fill ups.
t4r (Toyota 4Runner) | Fuelly
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
01-23-2013, 10:57 PM
Winter gas, poor road conditions, cold air and many other factors can decrease mileage during the winter.
-Ben
2006 Sr5 V6 4x4. DS 2.5/1.5, Waag brush & rear bumper guards, Vsc off mod, fog light mod, key & seat belt reminder disabled, weather techs.
01-24-2013, 12:23 AM
Wouldn't cold air help improve mileage based on increased air density and more oxygen per given volume of air? More power with cooler temperatures and less power with higher temperatures.
2004 4Runner 4x4 v6 SR5 Black w/Leather Bilstein 5100/FJ Swap @ 1.75
1998 4Runner 4x4 v6 SR5 Rear Locker Desert Dune Pearl w/Leather
01-24-2013, 08:19 AM
excess brake dust? May be a frozen caliper dragging you down.
01-24-2013, 09:24 AM
There is a different gas mix in the winter. I definitely notice a 1-2 MPG drop in the winter.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
01-24-2013, 11:29 AM
Real Name: Jesse
Real Name: Jesse
When is the last time you did a tune up on your runner?
I get the same mpg all year long 20-22. Sure winter gas sucks but in the summer I use my AC.
_____________________________________________
2016 Trail-P Dobinsons 302/325 DK Chromoly, 285 kO2, C4, RCI, BD Squad Sport, XD Phillips HID's, Tint, Husky liners, Crestone Rack
2020 Gx460
2000 Limited 4X4 - OME 881/890- B&M 70264
Overland Bound #10926
01-24-2013, 11:42 AM
I agree with you that you will get worse mileage in the winter for the reason you point out and for other reasons previously mentioned. My point was that cold air is not the culprit of the loss in milage.
01-24-2013, 12:33 PM
Real Name: Jesse
Real Name: Jesse
Yea cold air has nothing to do with it.^^^I always understood that cold air is more dense and combusts more efficiently and in theory should give you better mpg.
I think it relates to driving habits, quality of gas you put in your truck, tires, and maintenance.
if you are runnin a big heavy at tire and a lift you wont see 20mpg.
2020 Gx460
Reason: i spell bad
01-24-2013, 03:35 PM
Real Name: Mike Davies
Winter is always bad for mileage especially if you do short trips. A cold engine is not efficient, the gear boxes are more difficult to turn do the the heavy lubricants. Even tires have more rolling resistance.
01-24-2013, 03:39 PM
You might want to borrow or invest in a ScangaugeII
ScangaugeII
Great tool to get a feel for what impacts your gas mileage.... For me (2003 V8) I've learned that its:
Engine temperature - Before being fully warmed up my mileage is typically under 10mpg.... After warm up it's closer to 20mpg... For my normal commute (35 miles) it averages out to around 18mpg...
Speed - I used to drive over 70mph pretty regular.... The scangauge pretty much cured me of that.... Gas mileage is much worst once I hit 70+....
Acceleration - Strong acceleration from a dead stop usually is in the 4-6mpg range.... Once I get to speed it returns to the normal range....
HCF - I took mine out based on some of the posts I read and saw a .5mpg improvement.... Quick and easy gain....
Hope this helps.....
2003 V8 Limited
aFe filter, V-Led interior lights, RCI skid plates, Brembo rotors, NAPA lifetime reman calipers, Stoptech brake lines, WMW "fedrlbiker" roof rack
01-24-2013, 11:46 PM
FWIW, I'll be driving from warm Miami to Seattle on Saturday and passing through Denver and into Nevada. I'll also be keeping a close record of the fuel economy as well as the temps we see while on the trip. Seeing as to how I have a stock v6 right now it should give a decent idea as to how much all this really affects the vehicle as well as elevation changes.
01-24-2013, 11:53 PM
Real Name: Jon
Real Name: Jon
Originally Posted by fo'dilly
FWIW, I'll be driving from warm Miami to Seattle on Saturday and passing through Denver and into Nevada...
Sounds like a great road trip !
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
94 t4r fuel economy
james power |
Classic T4Rs |
11 |
09-18-2012 07:17 PM |
Fuel economy
NukeProf |
5th gen T4Rs |
20 |
07-14-2011 08:30 AM |
fuel economy
panos44 |
General Discussions |
3 |
03-27-2011 10:49 PM |
Fuel Economy
Village Idiot |
4th Gen T4Rs |
0 |
06-27-2005 05:52 PM |
V6 fuel economy
mpsrent1 |
4th Gen T4Rs |
1 |
04-19-2004 09:47 PM |
