Old 12-06-2013, 04:17 PM #31
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
Originally Posted by NuclearN8 View Post
I'm sorry, I didn't ready anything past you bought an 2005 with 22,800 miles... congrats to you for finding that is that's the actual mileage...
Yeah I thought it was a typo when we first looked at it. It's still immaculate and only has past 29k miles now. Should last a good while...
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 12-06-2013, 04:49 PM #32
LOSTR4's Avatar
LOSTR4's Avatar
Here are a couple others...
Old 12-06-2013, 07:04 PM #33
cloh09 cloh09 is offline
Registered User
Real Name: Chris
cloh09 is on a distinguished road
Registered User
Real Name: Chris
Client Validation
This is the Waag brush guard mine came with. I loved the look of it. I hit a deer at 50+mph and it killed the deer instantly. Full size doe. The damage was limite to cosmetics (bumper, grill, headlights, fenders, etc.). The fenders were replaced because the headlight covers snapped back and hit the corners. I always liked the look of it and I was able to mount some driving/fog lights right on.
The brush guard was connected with 4 brackets and saved my radiator and everything else mechanical in the front of the engine. The brackets got bent so I removed it. I plan on straightening them out and adding a lick of paint and putting it back on one day. This thing saved my runner from being totaled. It was in the shop for 5 days. Now it looks brand new.
Look into these, I give them a thumbs up.
Just Found-image-jpg
cloh09 is offline   Reply With QuoteReply With Quote
Old 12-07-2013, 11:49 AM #34
LOSTR4's Avatar
LOSTR4's Avatar
I appreciate the WAGG validation but I ended up spending a couple more bucks with a group deal last fall and bought a Shrockworks front bumper. So far I'm overly pleased with the results. It should stand up to the abuse it has plans for.
Old 01-22-2014, 11:42 AM #35
LOSTR4's Avatar
LOSTR4's Avatar
This last weekend I leveled my ICON suspension since the install of the SW bumper and I essentially went 4 times around to put me at 38.125" from ground to fender up front and held the 39.125" from ground to fender out back to hold a modest rake. First test drive was great, actually, nothing changed aside from feeling a little taller...after a day of use, the DS front end now has an interesting clicking/clump noise that occurs when the tires meet irregularities in the road (bumps). The performance feels the same but this noise is annoying/alarming. Has anyone experienced this before? It almost sounds like the Icon reservoir 90* elbow that feeds the shock is hitting the top hat of the shock tower...but I don't think it is this....and why only on one side? Any help will be appreciated.
Old 01-22-2014, 03:42 PM #36
LOSTR4's Avatar
LOSTR4's Avatar
Clickity click...help me quick....please
Old 01-22-2014, 05:03 PM #37
darkie3495's Avatar
darkie3495 darkie3495 is offline
Moderator
darkie3495 will become famous soon enough
Moderator
darkie3495's Avatar
So this noise only started after you leveled your Coilovers. are you seeing any wear marks on any component from touching each other? all bolts are tight, right? does the sound get louder when the suspension loads and unloads on larger obstacles? I've had multiple noises on mine but never after adjusting the coilovers.
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
darkie3495 is offline   Reply With QuoteReply With Quote
Old 01-22-2014, 06:04 PM #38
LOSTR4's Avatar
LOSTR4's Avatar
Correct, the noise only started after the adjustment...however, not immediately after. I did a loop of 50 miles, let it sit, the next morning I noticed the noise...I see a little wear (dust removed from coils) from the reservoir hose to the shock itself but that was easy to move the hose off the coil. My inner fender "could" be the culprit as it's just sitting in the SW bumper shrouds...but I couldn't imagine that I would hear it on the inside. I'll attempt a larger obstacle to see if the noise becomes louder. Bolts will be checked too but I wouldn't assume them to be terribly loose...A double check will warrant that true or not though. I don't think it has been lifted out of the range Icon suggests after only 4 rotations but the thought has crossed my mind...
Old 01-22-2014, 06:37 PM #39
xxaarraa xxaarraa is offline
xxaarraa is on a distinguished road
Seems like a sweet low mileage find, enjoy! I'd look into Avid lightbars. Though they are light bars, they attach to the frame and seem pretty solid, I'm a fan.
GONE - 08 T4R - 4" Lift with OME 885/895 & Bilstein 5100s, Toytec top-out spacer, Daystar 2" spacer, 1.5" Body Lift, 275x65x20 Duratracs (34.1"), Light Racing UCAs, Spidertrax, Toytec Diff Drop, 5th gen brake upgrade, SS brake lines, Budbuilt 5 piece skid kit, CBI sliders, Avid light bar, Hella 500ff with HID conversion, Curt front hitch receiver, ARB Awning, Uniden/Comet CB, Rostra seat heaters, Dynamatted interior
Corvette C7 Z51 | Ford Raptor | Aprilia RS250 | Aprilia RSV4 | Ducati 848 Corse
xxaarraa is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 10:33 PM #40
LOSTR4's Avatar
LOSTR4's Avatar
Bringing this thread back from the dead! I'm at 105k miles now. I've done the TB, WP, thermostat et Al and have rebuilt my Icon coilovers... she's running great and still makes me smile! I just got a side exit Gibson exhaust I'm throwing on...I need a new gasket befote its buttoned up, but I couldn't resist some open dump braps!
open exhaust before Gibson Exhaust is fully installed... - YouTube
Sent from my SM-G991U using Tapatalk
Old 04-06-2024, 02:29 PM #41
LOSTR4's Avatar
LOSTR4's Avatar
I threw on a Gibson exhaust cat-back side exit.... deeper than OE at idle and a great low rumble-rasp at WOT...Very easy kit to throw on!
Gibson side exit catback exhaust on a 2005 4runner 2uz - YouTube
Old 04-12-2024, 11:09 AM #42
LOSTR4's Avatar
LOSTR4's Avatar
I've been driving around and loving the new exhaust! I also threw in a voltage booster for my AGM battery...you just throw it into the ALT-S fuse and it tricks the alternator to produce more voltage to keep the AGM charging requirements in check...sporting a reliable 14.9volts while first starting and driving for about 30 min and it goes down a couple tenths as it's "topped-off" by than. All good things! Here's the voltage booster I used: Mini Fuse AGM Battery Voltage Booster For Toyota 4Runner, FJ Cruiser, & Tacoma | eBay
One can also use a Ford/GM diode - as long as it's placed in the right direction...you'll know if you have it backwards as you will likely have a battery light on the dash...
Old 04-20-2024, 06:36 PM #43
LOSTR4's Avatar
LOSTR4's Avatar
I just knocked out the infamous throttle body coolant bypass in the runner's 2uz...pretty easy but the lines were hugging the nipples something fierce...it'll be nice reducing the temperatures on the intake manifold without the 200°F coolant running through it.
I think I found one!!!!!!! ScarabArtistry Classic T4Rs 10 05-13-2012 01:07 PM
Look what I found! Smobien 4th Gen T4Rs 12 04-09-2012 03:49 PM
Found a T4R to buy... CoMarc 3rd gen T4Rs 6 09-18-2008 05:33 PM
I found something out... mole177 4th Gen T4Rs 7 02-08-2006 06:30 PM
Found a 96 SR5 with only 70,000 Aggie03 3rd gen T4Rs 7 06-24-2005 10:50 PM
