Checked the vehicle out tonight and overall it looks to be a solid buy. The 4wd system seems to be in good shape. I went from 2HI to 2LO to 4LO and back about 5-6 times. Never made any noises and all the lights looked good.
The woman has no maintenance records at all and doesn't think any maintenance has been done to it, which kinda scares me, but since it has such low miles and the 4wd system works, I think it's a risk I'm willing to take. I was able to knock another $500 off the already low price by telling her I was going to need to spend money to change all of the fluids in the vehicle. She had no issue with that.
The rubber hoses and belts under the hood looked good, and the battery seemed to be relatively new. It was in good condition anyway and the vehicle started up right away. All window actuators seemed good.
The vehicle has upgraded wheels (20" ... yay...) which I wasn't thrilled about because if I turn the steering wheel lock to lock, the tires slightly rub on the fenders. The good thing is that I didn't see any wear marks on the fender or the tires. The tires look to be almost brand new Toyo Proxies.
Is there anything else you gurus can recommend that I check out? I am going to do a second test drive on Saturday morning and get the car moving on the freeway and see how it is at higher speeds to make sure there are no noises. I wasn't able to do that tonight because it was rush hour traffic. If everything goes well Saturday morning, then I'll be buying it, and able to call myself a proud owner of an almost new 4runner
Edit: only issues I noticed are that the plastic trim has some sun fade which I am hoping to clean up a bit when I detail it, and the body paint has some hard water spots in a few areas but the paint is not in bad condition by any means.
