Real Name: Patrick
Real Name: Patrick
12 Volt outlet Not Working
A while back i attempted to use a 12 volt splitter to power a GPS and charge a phone. As you can imagine the outlet does not work and also the outlet in the cargo area either.
I checked the fuses and they are all ok. It their something i missed? Any other type of breaker or fusible link in the 12 volt Cig/power outlet?
Thanks
2007 Limited V8, AWD, Pelican Storage Cases, Radflo 2.5 Kit. Metal Tech Rear Offset Lower Links. 265/65/18 BFG TKO. Redline Full Synthetic lube, ARB Deluxe Bull Bar and SLEE ARB Foglight Light Surround with Rigid D2 Fogs and ARB LED Indicator/Markers. WARN 9.5XP. Dirty Parts Dual Battery Kit w/ rocker switch & Dual AGM Batteries. Gobi Stealth Roof Rack, ladder, Sunroof Insert, and Tool Box Stealth. ARB Diff breather kit.. (2) ARB Quick connect for jumpers and rear voltage access. Projecta Dual Battery voltage monitor. AGM Voltage Booster PRO “Texas Slim”.
