02-01-2013, 02:13 AM
Real Name: Dustin
Real Name: Dustin
Phone Mounting Options
Hi all, I am new to the forums and 4th gen 4runners in general. I will be purchasing a 4th gen this Saturday and wanted to get some ideas for cell phone mounting solutions.
I currently have a 3rd gen 4runner and am using a pro-clip mount and holder and absolutely love it. It is a little pricey but in my opinion, well worth the money you spend. I like the location of the mount on the 3rd gen but am not liking the 4th gen mount locations so much.
I will more than likely go with pro-clip again and deal with the fact that it blocks most of an AC vent but I wanted to see what others use to mount their cell phones in their vehicles.
My criteria is first that it has to be in a spot I dont have to look down and take my eyes off the road to see my phone (I use navigation and traffic apps a lot during my commute). Second, there must be room to plug my phone to charge while mounted. Last but not least, the whole mount must be secure...nothing worse than your phone bouncing around and flying under your feet while going 65+ on the freeway.
Anyone care to share their set up?
02-01-2013, 02:25 AM
This might work for you.
2004 4Runner 4x4 v6 SR5 Black w/Leather Bilstein 5100/FJ Swap @ 1.75
1998 4Runner 4x4 v6 SR5 Rear Locker Desert Dune Pearl w/Leather
02-01-2013, 05:19 AM
Reason: not reading whole post
02-01-2013, 08:27 AM
Go Proclipusa....I have mine mounted over the AC vent and hard wired the USB directly into the stereo. Location is perfect and not distracting. I keep the vent closed and there's still plenty of air flow from the other vents.
07 V6 SE | Bilstein 5100/FJ Swap @ .85 | VSC Override | Alpine INE-S920HD Nav w/ Rear Camera | Map Light Mod | LED Conversion | Bluetooth Integration | Bushing Upgrade | Heated Seat Conversion | Custom Console Organizer | AutoDim Mirror with Home Control | More to Come...
02-01-2013, 08:54 AM
I hate when they block the vents. Mine is a suction cup mount that secures to the windshield and I have it to the left of the steering wheel near the grab handle. It fits perfectly, looks good, within easy reach and does not block the view forward.
02-01-2013, 10:25 AM
I use a suction cup Ram mount. The suction cup is just small enough to fit on the center dash bezel right below the hazard flasher button.
John
'03 Limited 4.7 4WD - Overland 2.5
Camburg Uniball Uppers - 285-70/17 Toyo Open Country AT II
http://www.toyota-4runner.org/galler...er-thread.html
02-01-2013, 11:18 AM
Real Name: Chris
Real Name: Chris
My radio allows me to control the bluetooth, make calls, and look through my address book without pulling out my phone. It never leaves my hip holster
02-01-2013, 11:51 AM
I have a cheap temporary mount I bought from Walmart that works good. Needed it quickly about a year back. It has a suction cup that I mount to the windshield just left of center. A flexible arm extends out to the holder which sits in the notch above the radio on the front edge of the dash. I use it when driving on long trips and have had absolutely no problems with it coming loose, vibrating, etc. Listen to Slacker radio while using google navigation and gas buddy. It is easy to view and manipulate my phone while driving since it is just below eye level. Does not block any vents. Need all the air we can get in the summer Phoenix heat.
--<2004 4x4 Sport V6: FJ Springs and Bilstein 5100's All Around, Hidden Hitch Receiver, B&M 70264 Transmission Cooler, Weathertech Floormats, Brake Line Mod, Sway Bar Mods, Tekonsha Brake Controller and Dual Outlet Ashtray.
2014 Eclipse Evolution T225: Our house on wheels!
02-01-2013, 12:00 PM
Real Name: Dustin
Real Name: Dustin
I am thinking of going with the model that straddles that vent horizontally. It attaches to the plastic in the center dash unit so it's not actually attached to the vent. It has a small amount cut out to allow some air flow at least. I think I can get away with sliding it a bit up or down too to allow more air to pass by.
That's pretty slick. How sturdy is it? Does the suction cup ever release unintentionally?
2008 4Runner SR5 4x4 (Galactic Grey Mica)
Got Satoshi? - Compiled: Satoshi Build, Help & Picture Thread
02-01-2013, 12:03 PM
Real Name: Dustin
Real Name: Dustin
I use navigation and Waze a lot so my phone must be visible when driving otherwise I might do the same.
02-01-2013, 12:16 PM
Real Name: Jeff
Real Name: Jeff
I have a universal suction cup mount from Verizon ($20-$25 i think). Works and looks great!!! I like it mounted on the dash better than windshield...
2006 SR5 4X4 V6 - 98k - Shadow Mica
5100'[email protected], FJ Coils, Magnaflow 22" w/ Side Exit & Res. Hack, HIDs: 5000k Lows, 3000k Fogs, LED Rev, White/Blue Gauge/HVAC Swap, Int/Ext LED Swap, Foglight Mod, Custom Grille, Plasti-Dipped, Debadged, Weathertechs, -HCF, AVS In-Channels, Remote Start, Rodloft Pro, Firestone Dest. A/T 265/65/17s My Thread
Floating Rear Accessory: 18' Lund Alaskan
02-01-2013, 01:27 PM
Yep, that's what I use and suction cup it right there.
08 Limited 4WD, Cornfed 3/2 Lift, 35w 5000k HID Headlights, 35w 3000K HID Fogs, 1.5" Spacers, 275/65/18 Nitto Terra Grapplers
02-01-2013, 02:54 PM
Ram suction cup mount right on the rh bezel below the hazard light button, as pictured above. My mount is an x shape, so I also turn it sideways and use it fr my GPS too. Easy, versatile and out of the way.
2007 4Runner Sport V6, 58K km, stock for the moment...
And Then I go Very..Very..Fast. But, The Bike It's aahh.... Not soo Good.
So, I pooosh Harder. And then the Bike Smoke.. And that is Very ...Very Bad. " -- Valentino Rossi
