Old 04-18-2013, 11:35 AM #16
rooneyy's Avatar
rooneyy rooneyy is offline
rooneyy is on a distinguished road
rooneyy's Avatar
it's my pleasure, I know what you mean. I have been to several threads where I have had the same issue but there was no resolution ever posted.I have one hundred and twenty thousand miles on my 4 runner.
rooneyy is offline   Reply With QuoteReply With Quote
Old 11-11-2017, 05:27 AM #17
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Originally Posted by rooneyy View Post
Hello everyone!
I find this a little odd and I have searched to no avail.
This occasionally happens...I'm driving along and then I'll either slow down or stop all together then accelerate again and the car rev's but doesn't move then suddenly jerks forward. Then it will continue to drive normally again. It's as if I am pressing on the gas to about 1000-2000 RPM's while in neutral then putting it into Drive suddenly, except I'm not. It feels like the car is doing that on it's own randomly.
It's a little hard to explain. I will continue to do some research and hopefully come up with something. Thanks for your input guys and gals!
I have developed this same problem... except the transmission isn't throwing any codes.
As Rooneyy had, I brake hard to a crawl and then roll into the throttle to get going again and I find the truck feels to be in neutral... then it kicks itself into first gear and gives us all whiplash. The sensation feels like being rear-ended by something big.
Without a code, there's no way to know what's wrong. Has anyone had this happen before?
Truck in question is an '05 Limited V8, ~278000km
Any help is appreciated.
Thanks
Keros is offline   Reply With QuoteReply With Quote
Old 11-11-2017, 02:19 PM #18
52577 52577 is offline
52577 is on a distinguished road
I once owned a 2009 Saturn Sky roadster that had this same problem. It is a known issue within the sky/soltice community. I don't know if it is the same issue as the 4Runner, but I'll post the link to the solution. Hopefully it helps.
Click below and scroll to the top of the thread. There is a very knowledgeable write-up explaining why.
Saturn Sky Forums: Saturn Sky Forum
My previous '03 Sorento also had the same problem, but never got resolved. If I find out I'll post that as well.
52577 is offline   Reply With QuoteReply With Quote
Old 09-19-2022, 05:06 PM #19
Wells1203 Wells1203 is offline
Wells1203 is on a distinguished road
Originally Posted by oljedi11950 View Post
So I had time to finally take it to the shop to have it looked at. The issue is a bad transmission solenoid that is stuck in the ON position. So this was a special order part from Toyota which costs $195 and 4 hours of labor. All in all I am looking at about $700, it's a little steep but I'd rather get it done now and right before it leads to other issues. Hope this helps anyone with this same issue!
Rooneyy did you ever get this fixed and curious if you did, did it help? Thanks! Having similar issue but it doesn’t jerk that hard just kind of feels like I have my foot on the brake pedal as I’m trying to take off.
Wells1203 is offline   Reply With QuoteReply With Quote
Old 09-19-2022, 07:21 PM #20
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
Question
Am waiting to read if the $700 repair fixed it.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 02:43 PM #21
billbuckets billbuckets is offline
billbuckets is on a distinguished road
I would like to know if the fix was successful also
2007 Sport Edition 4.0 V6 4WD - Dobinsons IMS, JBA HD UCA, SuperPro Double Offset LCA, Sony DSX-GS900 Head Unit, Alpine Type-S 12" Subwoofer, JBL GTR-601 Amplifier
billbuckets is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 06:18 PM #22
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
This is the exact fix, replacing 2 solenoids fixes the problem. I just had it done- more details here:
https://atracom.blob.core.windows.ne...2010_12_30.pdf
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 03-19-2023, 11:48 PM #23
rooneyy's Avatar
rooneyy's Avatar
Thanks for posting the fix @duffdog . I never got around to it years back. It was indeed 2 solenoids.
06 Limited | 280,000 Miles
Suspension: Tacoma TRD Pro 4x4 Lift w/OME 895e rear springs | 1.25" SpiderTrax | Streetrays 1/2 aluminum spacers
Lights: Caliraised Pod Ditch Lights | Triton 40" Light Bar
Mods: Tailgate Hatch Open button | Tailgate rear window control | Raptor Lights | OrangeBoxx PSD's
Old 03-23-2023, 06:21 PM #24
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
I just thought I'd throw this out there...
When you have transmission issues like this, before tearing into valve bodies and replacing solenoids, get a can of De-Oxit and find the white connector on the driver's side of the transmission, just below the gas pedal.
This area seems to breed corrosion and those little pins need to stay clean -- they transmit signal between the ECM and the valve body. If they can't talk openly, then strange things happen.
Carefully pull apart hte connector and look around in there with a flashlight. I bet some of the pins have green gunk on them. Give both sides a good spray, let them dry for an hour or so, coat the outer seal with dielectric grease to keep more moisture out, and see if that works.
It's helped me twice so far!
Montego Murph is offline   Reply With QuoteReply With Quote
4Runner won't move forward in Drive when cold txt4r 3rd gen T4Rs 45 11-05-2017 08:17 PM
Truck jerks forward at stop? xmytruck 4th Gen T4Rs 28 08-07-2015 01:50 PM
2010 4Runner - Car Suddenly Dies and...... skippystang 5th gen T4Rs 15 01-28-2011 10:49 AM
Headlights suddenly went out on '06 SE 4Runner Mikhael Kampana 4th Gen T4Rs 3 11-29-2010 02:26 PM
99 4Runner 2WD jerks/clanks when shifting into drive or revers (or back and forth) fishcharmer 3rd gen T4Rs 4 02-07-2010 12:28 PM
