Old 02-02-2013, 03:50 AM #1
rooneyy's Avatar
rooneyy rooneyy is offline
rooneyy is on a distinguished road
rooneyy's Avatar
4Runner Suddenly jerks forward after pressing gas
Hello everyone!
I find this a little odd and I have searched to no avail.
This occasionally happens...I'm driving along and then I'll either slow down or stop all together then accelerate again and the car rev's but doesn't move then suddenly jerks forward. Then it will continue to drive normally again. It's as if I am pressing on the gas to about 1000-2000 RPM's while in neutral then putting it into Drive suddenly, except I'm not. It feels like the car is doing that on it's own randomly.
It's a little hard to explain. I will continue to do some research and hopefully come up with something. Thanks for your input guys and gals!
rooneyy is offline   Reply With QuoteReply With Quote
Old 02-02-2013, 04:16 AM #2
HB 4X4's Avatar
HB 4X4 HB 4X4 is offline
HB 4X4 is on a distinguished road
HB 4X4's Avatar
It could just be the driveline clunk. Do a search for it and you'll find dozens of threads about it. It's a simple fix if that's what it is- just lube the drive shaft.
2007 4X4 V8 Sport Edition
Build- DMZ Fab | Total Chaos +2" LT | Gobi | Shrockworks | Demello | ARB | BudBuilt | etc...
Pinnacle Exposure Photography
HB 4X4 is offline   Reply With QuoteReply With Quote
Old 02-02-2013, 05:16 AM #3
JoH4'08 JoH4'08 is offline
Real Name: Josh Griego
JoH4'08 is on a distinguished road
Originally Posted by rooneyy View Post
Hello everyone!
Mine does the same thing, I have a 2008 SR5 i bought in Aug. '12 with 142,000mi and it does it randomly too. Its happens mostly when I am at a stop and give it gas, it feels like the car behind me is bumping into me.
JoH4'08 is offline   Reply With QuoteReply With Quote
Old 02-02-2013, 11:47 AM #4
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
Same here, it seems related to the traction/stability mgmt systems. Mine is accompanied by a noise near the brake pedal too, sometimes its the sound of a spring releasing and then full power compes back to the throttle.
I asked at the dealer and they say its normal, to control how much power you put into the trans when you shift quickly back into drive. blah, blah, blah.
Mine is worse when I back up and then go forward, it can easily be a 3-4 second delay.
I get that it may be there for protecting the trans when rolling back and shifting into Drive, but mine has gotten worse over time. I think the mechanism making the spring noise of the culplit but have not really looked into it further yet.
Let us know what you find out, there are other posts on this issue to I know its somewhat prevalent.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 02-02-2013, 12:23 PM #5
Burt Burt is offline
Burt is on a distinguished road
Yep, very common. I lube the drive shaft once a year and it hasn't came back.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 02-02-2013, 01:47 PM #6
lehiguy's Avatar
lehiguy lehiguy is offline
Real Name: Mike Davies
lehiguy is on a distinguished road
lehiguy's Avatar
The engine revving up and then suddenly you experience movement is most certainly NOT as simple as a slip and spline that needs grease. You have a tranmission issue. Either you are low on fluid, have a clogged filter, internal leaks, etc. I would get it checked out and flushed ASAP. Sealed tranmissions with "lifetime" fluid is a load of crap. There is no such thing in reality. It needs service.
lehiguy is offline   Reply With QuoteReply With Quote
Old 02-02-2013, 02:02 PM #7
Greydog's Avatar
Greydog's Avatar
Sorry Rooneyy, I read too fast (missed the reving part).
I agree with Lehiguy, if the endgine is reving but there no immediate forward in gear, then there is a trans issue perhaps.
Old 02-02-2013, 04:06 PM #8
rooneyy's Avatar
rooneyy's Avatar
Many thanks for everyone's input. I will get it checked out.
Old 02-08-2013, 05:34 PM #9
ryanbt's Avatar
ryanbt ryanbt is offline
ryanbt is on a distinguished road
ryanbt's Avatar
Mine does the same thing. After it's been in reverse, come to a complete stop, and put in drive and start moving forward about a second later it accelerates a bit more than I would have pushed the pedal. No noise or anything. This seems to be more noticeable if I have the wheels turned. (backing out of my driveway or a parking spot when I'm turning directions is where it happens the most). Please report back your findings.
CURRENT: '14 Limited Mag Gray, '17 Limited Mag Gray, '19 Mercedes GLC300, '08 Urban Runner | SOLD: '96 4runner SR5, '08 Urban Runner, '14 Limited Blizzard Pearl
ryanbt is offline   Reply With QuoteReply With Quote
Old 02-08-2013, 09:49 PM #10
lehiguy's Avatar
lehiguy's Avatar
That may be normal. Torque converters are like variable ratio hydraulic clutches. When you start off, there will be, depending on the specific machine, as much as a 3:1 reduction at the converter, let alone what the actual gear ratio is for first gear. That ratio reduces with speed and decreased load and would be felt as acceleration. Again, what you are feeling MAY be normal... maybe not.
Old 02-09-2013, 02:44 AM #11
rooneyy's Avatar
rooneyy's Avatar
Sorry things have been so hectic I haven't had time to had this looked at. As of right now though, it hasn't happened as much if at all. I will definitely report back when I get it check out.
Old 03-09-2013, 12:09 AM #12
rooneyy's Avatar
rooneyy's Avatar
Still need to get this fully diagnosed but I have narrowed it down to do this everytime I brake hard. It is guaranteed to happen every time i brake that hard.
Old 04-15-2013, 07:59 PM #13
rooneyy's Avatar
rooneyy's Avatar
So I had time to finally take it to the shop to have it looked at. The issue is a bad transmission solenoid that is stuck in the ON position. So this was a special order part from Toyota which costs $195 and 4 hours of labor. All in all I am looking at about $700, it's a little steep but I'd rather get it done now and right before it leads to other issues. Hope this helps anyone with this same issue!
Old 04-15-2013, 09:26 PM #14
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
Thanks for letting us know what was wrong. To many people post problems and then never come back to let us know the fix. How many miles on your 4runner?
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 04-15-2013, 09:54 PM #15
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
4Runner won't move forward in Drive when cold txt4r 3rd gen T4Rs 45 11-05-2017 08:17 PM
Truck jerks forward at stop? xmytruck 4th Gen T4Rs 28 08-07-2015 01:50 PM
2010 4Runner - Car Suddenly Dies and...... skippystang 5th gen T4Rs 15 01-28-2011 10:49 AM
Headlights suddenly went out on '06 SE 4Runner Mikhael Kampana 4th Gen T4Rs 3 11-29-2010 02:26 PM
99 4Runner 2WD jerks/clanks when shifting into drive or revers (or back and forth) fishcharmer 3rd gen T4Rs 4 02-07-2010 12:28 PM
