07-23-2018, 08:58 PM
#211
Originally Posted by having fun
It's got pep now. When loaded down, going up hill, I get in that 70+ speed, I have to go pretty deep on the pedal for it to down shift. Just have to do it manualy.
I love the build and your youtube videos- nice looking stance you have there. I'd still take a built 4th gen over a 5th gen anyday.
07-24-2018, 01:16 AM
#212
Real Name: Leonard
Real Name: Leonard
Appreciate it! These are comfy, play toys.
Having fun's build
07-30-2018, 11:11 PM
#213
Real Name: Leonard
Real Name: Leonard
Done adding to the bumper. Added some lights in it, Luke should just do this to them IMO, and got it painted 1 color again.
Having fun's build
09-09-2018, 06:16 PM
#214
Real Name: Leonard
Real Name: Leonard
Having fun's build
09-09-2018, 07:39 PM
#215
Registered User
Real Name: Morris
Registered User
Real Name: Morris
looks awesome!
04-27-2019, 11:46 PM
#216
Real Name: Leonard
Real Name: Leonard
Well had to do some more things to keep her in shape and hopefully not break on me.
These upper links finally couldn't handle the flex stress I putting them through, so had RENZ Fabrication hook me up with some dbl offset arms, with Metalcloak bushings. Had him add a little more length to them for my pinion angle,
I notice with all my flex while was trying out a different size rear coil, my MT offset lowers also hit/bind with the axle. Had my shocks unhooked on one end, and it looks like the ICON 56550s might not be long enough either, oh shit. Might be close to limiting them out on full drop/flex.
I also developed a rear seal leak last yr after doing a regear, so did them and bearings while I had it apart. Figured while I was at it, might as well do a brake upgrade also.
New ebrake pads, and went with stoptechs Z36 kit.
Lot better on stopping this pig.
Having fun's build
04-28-2019, 07:53 AM
#217
Registered User
Real Name: Morris
Registered User
Real Name: Morris
mmmmm.....BEEFY!!....
07-15-2019, 11:10 PM
#218
Real Name: Leonard
Real Name: Leonard
Think I'm almost done. My buddy Krister decided to bump up his Dobinson coils again. So he was kind enough to have me try out Dobisons 701s. They gave a little more lift also. A little stiffer also. Was playing with spacers and coils.
So made a ride to the hills for a few days and was loaded down real heavy. Hitting the bump stops even with 1" spacers on the 677s.
So decided to put the 701s back in, remove spacers other than the driver lean spacer. The stiffness of these are toning down the harshness of the 886s up front. Good thing.
Final lift measurements.
F 23.5" = 4.5" lift
R 25.5" = 4.5" lift
Little stiff, but truck feel. Drop the air pressure a little, were good.
Having fun's build
07-16-2019, 02:46 PM
#219
Real Name: Will Oliver
Attachment 333157
Attachment 333158
Man, I have got to do this sometime soon. I feel like these rear links are just tooth picks. Looking through your thread has me feeling a little more motivated to get my work done on my truck.
Silver 2007 4Runner Limited V8 – BUILD THREAD
Owner at Sherpa Equipment Co. (Formerly Rocky Mountain Racks)
07-16-2019, 04:33 PM
#220
Real Name: Leonard
Real Name: Leonard
They are in comparison. OEM bushings where getting pretty bad also.
Depending on your lift height, add some length, and more flex able type bushings.
I come close to maxing my shocks out and there the longer ones. Lower links contact my axle at drop.
Having fun's build
09-03-2019, 05:57 PM
#221
Real Name: Krister
Real Name: Krister
Getting some at the Gate Keeper to Deer Valley.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
04-07-2021, 02:09 PM
#223
Real Name: Leonard
Real Name: Leonard
Having fun's build
04-07-2021, 02:33 PM
#224
Real Name: Leonard
Real Name: Leonard
Having fun's build
04-07-2021, 02:35 PM
#225
whats up old man!
