04-07-2021, 02:52 PM
#226
I heard you like to mall crawl
04-07-2021, 05:03 PM
#227
Real Name: Leonard
Real Name: Leonard
Just a little. Good to see you on board, might let you follow me around the mall some day
Having fun's build
04-07-2021, 05:33 PM
#228
Depends.. Arden or Rocklin? Arden has too many big speed bumps
06-06-2021, 11:53 PM
#229
They usually don't come off that easy, trail that is. I've bang mine up bad and they stayed on, just no body lift, tire hit the front and popped it loose. Removed after that.
I filled the holes in, this is the way she stays now.
First off, awesome build.
Do you have instructions and/or pics of how you did this? I keep tearing off these panels and I'm getting tired of repairing/replacing. It's getting harder and harder to find donor vehicles.
____________________________
07 T4R limited 4.0 4wd
Snorkeled, full BudBuilt skids&sliders, Dobinson's MRR LT rear, 701v, ET front, c59-354, Wilco Solo, 295/70r17 Patagonia MT, eBay Taco bumper heavily modded w/Smitty 9.5XRC, Yukon Zip locker rear, 4.56 regear, RESZ links, JBA UCA, Russian ATRAC mod, extended breathers, LED everything, etc etc etc
06-11-2021, 11:16 AM
#230
Real Name: Leonard
Real Name: Leonard
Thanks... I just used a flat bar and got behind them and pulled hard.
Having fun's build
06-11-2021, 11:30 AM
#231
My apologies, I would have specified.
I was referring to how you filled in the holes in the body where the plastic clips were.
I've considered fiberglass on the inside, Bondo to fill the holes and then touch up paint.
06-12-2021, 12:05 PM
#232
Real Name: Leonard
Real Name: Leonard
Used JB weld stick to fill, need access to the inside also to flatten/press together. After sanding to shape outside, used the liquid type to take imperfection out. Do believe there were a couple small holes next to doors edge that I had to weld no access.
Having fun's build
03-01-2022, 05:26 PM
#233
Well I decided to order a set of steel 1" bolt in spacers for the bucket area. Full 4" lift in the rear now. Front stayed at 23.5" hub to fender, approx 4-4.5" lift
Definitely toned the roughness out from the 886s.
Periodically, I find a few drops of water in the air box from going through small rivers, too much liner cut out. Snorkle out off the question as I tend to go into some really ruff tight spaces in the woods. So decided to do the Cowl install.
Attachment 288204
Hey, I've been looking into doing this for my 4Runner, but every picture I've seen has been a slightly different cowl than mine. Yours looks to be the same with the "vent" right above where you routed your intake. Have you had any issues with water or such getting into your intake? I live in Colorado so snow buildup near the windshield is going to happen as well as some heavy rain occasionally. I appreciate the help! Sweet build.
06 Galactic Limited on 33's, Rear locker, Bilstein 5100s, Toytec 2" Superflex Springs, Whitson Metalworks Rack, Squadron Sport Ditch Lights, Dual Viair 450cc Air compressors with 2.5 gal tank, Cobra 75WXST CB Radio
Build Thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
03-02-2022, 01:40 AM
#234
Real Name: Leonard
Real Name: Leonard
With mine being oval shape going into the wall, it sits/touches the underside of the gutter for the vent. It also sit a few inches from the bottom water roll off that get in there from the vents.... So far I haven't had water in my intake box but a couple small drops.
Having fun's build
03-05-2022, 11:26 AM
#235
Real Name: Matt
Real Name: Matt
You’ve built one helluva rig sir. Very cool!
I just read through the entire build. I have a question on your cowl intake. I did this mod not too long ago also. It looks as if you used maybe some rubber hose and silicone? It’s hard to tell. I used too large of a hole saw on mine. I had used some of that automotive door edging protector but it wasn’t thick enough to fill the gap and was squeaky on cold mornings. I removed that and have some household door and window weatherstripping now but I’m looking for other solutions.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
