02-16-2013, 11:06 AM
Real Name: Derek
Real Name: Derek
Kmc strikes, TOO MUCH OFFSET?
Alright, i'm in the boat for a new set of wheels. I'm currently at 3 inches of lift, and coming soon is my toytec 1 inch body lift. I've heard people at offroad shops saying that to run this wheel i'd have to have a larger lift without insane rubbing issues. I do know that with this combination my wheels will be sticking out of the fender, and that's exactly what i'm going for. So here is the wheel that i'm looking at.
http://www.rimzoneonline.com/categor...-availability/
It's a KMC Strike wheel, 17x9, with a -24 offset. I want to run it with 285/70/17 toyo open country at 2's
If that's not possible my other option is the KMC Addict wheel, which is a 17x9, with a -12 offset.
http://www.rimzoneonline.com/categor...8-Matte-Black/
SO if anyone can help me out with this it would be greatly appreciated. Thanks!
2004 toyota 4runner v8 4x4.
Bilstein 5100, Toytec Superflex, toytec/elibach front lift coils, 1 inch toytec body lift. 17x9 Method The Standard wheels, 285/70/17 Cooper AT3's, LC80 Snorkel
02-16-2013, 12:30 PM
Hate to rain on your parade but they are right. There is no way your going be able to get close to running that combo of wheel and tire without much more extensive modifications. OE offset is about 5.5 inches give or take. With the the setup you want to run you're going to have two major problems.
1) you'll probably get about 25 degrees of steering turn before you rub
2)with that large of a tire on that drastic of an offset change, your wheel bearings, knuckles, cv joints will last about 1000 miles before they're all shot.
02-16-2013, 12:33 PM
Real Name: Derek
Real Name: Derek
Gosh darn it! So how about the KMC addict?
02-16-2013, 12:36 PM
Real Name: Matt
Real Name: Matt
There are several people running those, and that backspacing on other wheels. I think it's close to stock + 1.5" spacers.
edit - you're still likely to have rubbing with 285s (with any wheel), but I assume you already know that.
02-16-2013, 02:16 PM
Real Name: Sergio
Real Name: Sergio
IMO the addicts look better anyway. and yes with 285s you will need trimming and probably body mount chop
2018 SR5 Premium
2013 Trail - sold
2006 v6 sr5 -sold
02-16-2013, 04:42 PM
Official Vendor
Real Name: Vin
Official Vendor
Real Name: Vin
You can run the 17x9 with -12 offset and 285s. Just be prepare for some cutting and chopping if you plan to go off-roading.
02-16-2013, 05:15 PM
I am running a 17x9 with the negative offset and had to do a bit of trimming to get it to work.
02-17-2013, 08:41 AM
Real Name: Derek
Real Name: Derek
I'm aware i'll be trimming and doing the body mount chop, but Mikey, how much do the wheels stick out of your fender? Or does it stay flush?
02-17-2013, 08:42 AM
Real Name: Derek
Real Name: Derek
Thanks for the reply! and yes i am aware that i'll need to be cutting, i'm just hoping not to do anything too drastic
02-17-2013, 10:58 AM
Real Name: Jon
Real Name: Jon
Stand out from the crowd; go with skinny tires ! No rubbing issues. Go anywhere your friends go offroad except mud and snow deeper than your diff.
I'm running 33's on wheels that have 4.5" backspace. No spacers, no body lift, no cutting or chopping and no rubbing. (except on my front mud flaps and I could always remove them)
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
Reason: clarity
02-17-2013, 12:15 PM
Real Name: Derek
Real Name: Derek
I would do that, since i'd have less rolling resistance with skinnier tires as well, but all I go through if i'm offroading is mud and snow!
02-17-2013, 12:39 PM
Real Name: Jon
Real Name: Jon
If you need float for sand or snow deeper than your diff then wider tires are better but overall, skinnier tires will get through to solid ground beneath and provide better traction.
For fun, watch: http://www.youtube.com/watch?v=UGWp8R-IqoE
The vehicles are all Rovers but notice what they are using for tires to get through beastly bad mud and all sorts of other conditions.
As an aside; avoid mud. It makes a mess and breaks things.
Safe travels, Jon
02-17-2013, 03:51 PM
They are pretty much flush, but that is on a 5th Gen. But the backspacing is good for both Gens
