10-26-2014, 07:47 PM
Real Name: Dan
Real Name: Dan
Light bulbs inside the running boards
A few months back, I replaced the factory’s weak amber interior lighting with something brighter, but not obnoxious. LED conversion for all reading lights, dome lights, all 4 door entry/step areas, and the cargo dome. I intentionally left the visor lights with the factory’s amber bulbs, but I may change those out in the coming months. Bought them for just under $20 from this vendor.
Right now, however, I want to replace the lights inside my factory running boards, as well as the reverse and license plate lights.
I haven't figured out how to pop open the light cap on the running boards. Would one of you be able to tell me if the bulbs inside it can be replaced with LED? I am thinking of using the LEDs from this seller on Amazon, which also includes tag and reverse lights.
Lastly, both sellers called their LED kits for "interior lighting". Is there any particular reason they couldn't be used as exterior lights inside a running board?
2008 4Runner V8 Limited ("Lewis"), all factory options.
10-26-2014, 07:54 PM
Go with an 8smd t10 bulb, buy a 10pack from Amazon and you'll be set for both the running and tag lights. The round type, with all the LEDs on a circle, and the flat blade t10 connector perpendicular to the led circle. Will fit in everywhere but the dome.
10-27-2014, 12:13 AM
running boards and plate lights are 194's as for the running boards the plug rotates out. its a bit hard but can be done in seconds
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
10-28-2014, 01:15 AM
Real Name: Dan
Real Name: Dan
What's the difference between 8-SMD and 5-SMD?
10-28-2014, 08:22 AM
Real Name: Matt
Real Name: Matt
3 SMD,
It's the number of leds. ...pull up Google images and compare for a visual.
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
10-28-2014, 11:31 AM
Real Name: Dan
Real Name: Dan
Originally Posted by HokieRunner
3 SMD,
Many thanks.
10-28-2014, 03:48 PM
Does anyone know where to get more of the running board sockets? There is some corrosion in mine and it's causing fuses to pop when they are plugged in. I've looked around and can't find anything.
10-28-2014, 03:57 PM
Go to the dealer and get a part number and order it online for half the price. Im not sure of the PN myself but someone might.
2008 Limited V6 2WD
LED interior lights, HID's, Plastidip'd emblems, Fire extinguisher, HCF delete, 25% tint.
12-09-2014, 02:39 AM
I know its a little late, but I just came across this thread as I also had a running board light socket issue too. I searched and searched all the online dealer illustrations and not a single one shows a lighted running board....odd.
Anyway a local dealer (who also could not find an illustration of a lighted running board) ordered me a non led third brake light socket 90075-60059 and it was the exact same socket thats in the running board. Expensive little sucker @ 13.50.
2005 4X4 V8 LTD 4Runner Black
Driver's side upper assist handle, tail/stop bumper light mod, Flowmaster 50 suv with side exit exhaust and Valor tip, 20% tint on fronts and 27% add'l tint on rear window, DIY blacked-out headlights, Stainless door sills, VIP Plus w/GBS alarm, OBX pedals, Can. hood protector, ash tray kit, '06 LED tails, T&H Euro bar, OME lift, Spidertrax spacers, LT275/70R17 Cooper AT3s, HIR bulbs in LB and fogs, VSC mod, AFE Pro Dry S filter, White LED cluster and HVAC
05-11-2020, 10:26 PM
Is that socket a straight or a right angle. I think the P/N is 90075-60005. The straight is 90075-60059.
jaaydee
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
