Old 06-26-2023, 03:23 PM #1
averyislost's Avatar
averyislost averyislost is offline
averyislost is on a distinguished road
Question V8 Transmission Cooler Upgrade (Questions)
Hello all!
I'm looking at upgrading my transmission cooler on my '03 4runner V8, which came stock with the small aux cooler up front. I've got a Scangauge to watch temps and I'd like to see them a little lower. I typically see around 170-175ish on the highway when cruising (this is pretty normal) but it can get up to 190 or so in the city during summer. This is with fresh Idemitsu TLS fluid.
I've already purchased a Hayden 679. but I guess I went one size too big because I simply could not find a non-janky location to mount it with the mounting kit I bought from them (basically just bar stock with holes).
What I'm looking for is hopefully some pre-made brackets to make the install a little cleaner/easier, or a full replacement that would be easy enough to fit.
The options I'm looking at that MIGHT work are:
Mishimoto FJ Cruiser/Tacoma Trans Cooler - looks like it may not work due to routing of the lower cooler line potentially interfering with the "rod" that juts out under the stock trans cooler to hold the forward metal AC line in place.
Mountain Passes Off-road mounting plate for Hayden 678 - requires a bit of work to relocate the horns, but instructions are for the GX470 so it could be slightly easier/harder to install. This looks like the best option, but it's on the higher-priced side.
KAON FJ Cruiser or Prado 120 Trans Cooler mount - fits the Hayden 678 as well. Found this through some searching. A guy on youtube fit it on his GX470, and did not have to re-route his horns and it only required drilling one additional hole in the bracket, much easier. However, it's tough to tell from the video but I am guessing it may run into some interference with the same "locating rod" that holds the AC line in place. Here's the video: Lexus GX470 Transmission Cooler Install! EASY!! - YouTube
Thanks! And sorry for the wall of text, but wanted to make sure the forum knew I did my research, lol.
'99 Millenium Silver Limited
Toytec/Eibach coils on 5100's, OME 890 rear coils, 275/70R18 Duratrac on Pro Comp 18x9's
'03 V8 4X4 Limited
Asfir skid plate, Eibach Pro Kit, Wilco Hitchgate Solo, Retrofit headlights, 265/70r17 Grabber ATX on Motegi Trailites
averyislost is offline   Reply With QuoteReply With Quote
Old 06-28-2023, 10:54 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
This is the cooler I'm currently running on my 03 V8. Works well. I have a Koyo radiator that does not have the internal cooler for the trans so this one is doing all the work and keeps temps low, even on the freeways.
Amazon.com
I use the OEM small cooler for the power steering now.
I am thinking about upgrading that to a slightly larger cooler but it's going to take a little more work to fit due to the larger size.
Amazon.com
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
cooler , hayden , line , trans , work
External transmission cooler install questions 4Runner303 5th gen T4Rs 1 07-19-2022 02:31 PM
Re-Routing Trans Cooler Lines In Line With Rad Cooler Questions nc-grayson 3rd gen T4Rs 3 12-07-2016 09:09 PM
TOYOTA OEM TRANSMISSION COOLER Trans Cooler nissanh For Sale: T4R Items 1 03-30-2013 10:24 PM
Transmission cooler and sway bar questions UpNorthMN 3rd gen T4Rs 3 04-09-2008 05:28 PM
Transmission Cooler Questions BTLFED 3rd gen T4Rs 5 01-15-2008 05:44 PM
