03-01-2013, 08:00 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Reverse light wire
I am trying to tap into my reverse light wire so that some extra lights come on when i put it in reverse. I looked at the plug on my tail light and think it is the red wire with yellow stripe. Can anybody confirm that? Or if anybody has tapped into the trailer harness for this, could you chime in as well. Thanks!
Morris
03-01-2013, 08:03 PM
Morris
Not sure which one it is, but make sure the lights you're adding are on a relay or LED's as to not overload the circuit.
03-01-2013, 08:04 PM
Morris
Bingo. Red with yellow stripe. Tapped it for my backup camera last weekend
2008 Urban Runner 4WD
TRD CAI, Husky Liners, 35% Front Tint with 50% over factory rears, FJ Springs, Bilstein 5100s all the way up, AVIC Z120BT, Sony Components, Alpine Amp, 10" Pioneer sub in Custom Stealthbox
My Audio Setup
03-01-2013, 08:05 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
These are LEDs so they hardly draw any power.
03-01-2013, 08:10 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Thanks. Where did you tie into the wire for your camera?
03-01-2013, 09:30 PM
There are access panels on each side of the cargo area that give you acces to the tail light wiring. I spliced into the wire right there.
My Audio Setup
03-01-2013, 09:51 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Yep, there is where i was looking. I also found out which wire is the reverse wire on the trailer harness. Thanks.
03-02-2013, 01:57 AM
i just made my own trailer plug and ran another wire for reverse lights
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
01-29-2015, 04:25 PM
Which was it
@ momo.75
04 4runner Sport Edition V8 4WD // X-REAS removed // Bilstein 5100s // Fj Cruiser coils // Interior LEDs // gshadow325 12V charger mod // Undercarriage LEDs // Back-up lighting // onboard 12v air compressor // 255/75/17 Duratracs // Homemade load bars // Smittybilt roof rack(when needed)
2016 T4R Trail Edition
2017 Civic Si
01-29-2015, 04:31 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Originally Posted by 28.
That was a couple years ago so i can't remember off the top of my head. If i get chance i will have to look
01-29-2015, 04:48 PM
Thnx i appreciate the help..
2017 Civic Si
02-07-2015, 10:54 AM
So, did we confirm its the red wire w white stripe to tap in the backup lights?
Let's see some pics of where you all are mounting your lights, too. I'm trying to find a solid base, that's fairly indiscreet.
05-22-2017, 08:47 AM
Real Name: Andrew
Real Name: Andrew
aaronfro17 stated it was the (Red Wire w/ Yellow Stripe)... this is still correct no?
2005 - 4Runner - Limited - V6
05-22-2017, 11:09 AM
If I remember correctly its a red and yellow wire that you can tap in to it on the drivers side near the floorboards by the door.
05-22-2017, 12:42 PM
Real Name: Derek
Real Name: Derek
Trailer harness tapped for reverse. I used the correct colors.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
