Old 03-08-2013, 12:11 AM #16
stanleybb50's Avatar
stanleybb50 stanleybb50 is offline
stanleybb50 is on a distinguished road
Thanks! I've literally been asking for someone to figure out this mod. Especially if we get less seizing issues...!
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
stanleybb50 is offline   Reply With QuoteReply With Quote
Old 03-08-2013, 12:38 AM #17
Ducmonsta's Avatar
Ducmonsta Ducmonsta is offline
Ducmonsta will become famous soon enough
Ducmonsta's Avatar
@Glock_19 your right front caliper was actually starting to seize. Nothing major, but you caught it just in time.
The piston in that caliper was a little difficult to press in.
Ducmonsta is offline   Reply With QuoteReply With Quote
Old 03-08-2013, 02:01 AM #18
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
This is awesome. I had been looking at upgrading my rotors so doing this mod might be in my future. Thanks for the write up. I wish I lived closer, I would just have you guys doing
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 03-08-2013, 11:20 AM #19
M1911 M1911 is offline
M1911 is on a distinguished road
If you changed to the sport backing plate, would that remove the need to trim?
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
M1911 is offline   Reply With QuoteReply With Quote
Old 03-08-2013, 11:34 AM #20
Ducmonsta's Avatar
Ducmonsta's Avatar
Great question!
You could install the backing plate from a sport brake system. However, it would require the removal of the front wheel bearing from the spindle. That is a lot to take on just for the backing plate.
Old 03-08-2013, 12:12 PM #21
Are there any potential problems that could be caused by trimming the backing plate like that? What does the backing plate do? Improve airflow to the rotor? Keep water and debris off the rotor?
Old 03-08-2013, 12:32 PM #22
Glock_19's Avatar
Glock_19 Glock_19 is offline
Glock_19 is on a distinguished road
Glock_19's Avatar
As far as I know it's just a dust shield. You should actually get improved air flow to your brakes if you completely removed them. My buddy has a CTS-V with no dust shields (it's mostly a track car).
2006 Driftwood Pearl SR5
Glock_19 is offline   Reply With QuoteReply With Quote
Old 03-15-2013, 09:37 PM #23
cleger's Avatar
cleger cleger is offline
Real Name: Cody
cleger is on a distinguished road
cleger's Avatar
Real Name: Cody
Originally Posted by Ducmonsta View Post
Rotors are from EBC. They are the sport rotors. Calipers can be had at any local auto parts store. We opted to go with the OEM ones. If anything leaves our shop with our stamp of approval, it has to have quality components. I always recommend oe vs. aftermarket.
Okay, quick question... I am looking on a few online parts stores that sell ebc rotors, a lot of them say that under fitment that they fit the sport, sr5, and limited, so that means that they are the same size.. how do I find the bigger rotors?
http://www.toyota-4runner.org/attach...1&d=1363397467
4th Gen Brake Upgrade Glock_19 by Ducmonsta-fitment-jpg
cleger is offline   Reply With QuoteReply With Quote
Old 03-16-2013, 04:43 PM #24
jdkilroy's Avatar
jdkilroy jdkilroy is offline
Real Name: Jon
jdkilroy is on a distinguished road
jdkilroy's Avatar
Real Name: Jon
Another interesting tid-bit:
My 2008 V8 SR5 has the 13WL calipers. So I have the larger size calipers with the slightly smaller diameter rotors.
But.... I can (and do) use 16" wheels; and that, to me, would seem to be the most versatile combination.
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
jdkilroy is offline   Reply With QuoteReply With Quote
Old 03-16-2013, 05:20 PM #25
NeutronJon's Avatar
NeutronJon NeutronJon is offline
NeutronJon is on a distinguished road
NeutronJon's Avatar
Great question!
I actually finished this same mod this morning. I did the left side a few days ago and simply bent the dust shield back out of the way of the larger rotor. I wait until this morning to do the right side because I had the early signs of a problem with the wheel bearing. I used an electric trimmer to cut the edges back similarly to how it is shown on this thread, and then rounded the edges with a grinder.
I had planned on leaving the dust shield off, but my friend (30+ year mechanic) said to keep it. He said the main thing he was concerned about was keeping the brake dust off the CV boot. One day I may replace the one I bent back on the left, but it hasn't given me any problems in the short term.
The wheel bearing was quite easy to pull from the spindle. An air impact driver with a 35mm socket to remove the axle nut, and then 4 17mm bolts holding the wheel bearing to the back plate. Once the bolts were loosed all the way out, a three jaw pulley puller was used to slide the wheel bearing off the spindle while keeping it straight. The whole job on the right side took about 2.5 hours. That includes pulling and replacing the wheel bearing a second time because we put it on the first time without the dust shield. One of the hardest parts was getting the dust cap off without damaging it. I recommend using a painters tool and a small hammer to slowly back the dust cap out of it's mount.
2005 Limited V8- Stratosphere Mica
LED Interior, Constant Fog, OEM Nav, Encore E9 Alarm/Remote Start, Rear Air/XREAS converted to FJC, Vantrue R2 Dash Cam, Camburg BJ UCAs, Bilstein 6112s, CBI ditch brackets with Auxbeam 4" flood LEDs
NeutronJon is offline   Reply With QuoteReply With Quote
Old 06-05-2013, 04:32 AM #26
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
any real noticeable increasein braking power?...am still on the fence about doing this mod
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 09-26-2013, 06:41 PM #27
manp0899's Avatar
manp0899 manp0899 is offline
manp0899 is on a distinguished road
manp0899's Avatar
I am curious about doing this as well. I have been very disappointed with the braking performance that I had so far, esp compared to the FJ and gx470. Has this actually improved the responsiveness and have you seen a noticeable difference in braking power?
manp0899 is offline   Reply With QuoteReply With Quote
Old 09-26-2013, 06:58 PM #28
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
The brake backing plate does a couple things, first it helps prevent debris and such from getting between the back of the rotor and the hub, ect ect. Second, it funnels air through the rotor to cool it much like the ducting on high end sports cars and race cars. The air flow is supposed to go through the back of the rotor and out through the edge if I remember right.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 09-27-2013, 12:49 AM #29
@BlackWorksInc ..............u suggesting trimming the plate is a bad idea?.......but thats about the only option for the brake upgrade.............unless of course going the other tedious route of pressing out the spindle and installing the correct backing plate size
Old 09-27-2013, 01:08 AM #30
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Great question!
just buy the sport backing plates ahead of time. and swap them over whenever you do the bearings.
but, just pulling the bearing off shouldn't be too bad. just 4 bolts, and the axle nut.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
brake upgrade q avenged yoda 3rd gen T4Rs 3 12-05-2011 11:34 AM
EBC Brake Upgrade pcooke1 4th Gen T4Rs 17 03-24-2011 09:39 AM
Brake upgrade macoyle 4th Gen T4Rs 1 02-20-2011 03:21 PM
SE brake upgrade? Teqeeler 4th Gen T4Rs 5 02-02-2010 01:46 AM
