11-07-2013, 08:39 PM
#46
Real Name: Alex
Real Name: Alex
Originally Posted by satanos6668280
Major diff ive noticed is that after alot of high speed stops fade and pulsation are not a factor where with my smaller wg calipers I would get a pulsation after alot of highway driving. But as far as stoping power ive noticed no difference.
So... does it seem worth it at this point?
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
- Helpful DIY Videos
11-07-2013, 11:12 PM
#47
Real Name: George
Real Name: George
If you gotta change the calipers anyway than yes its worth it because you reduce the chance of warping a rotor if your gonna do it just to do it then I would say no
04 limited v6 4wd 6" rough country fj lift pn#770s 35 12.5 17 wrangler mtr tire method 17 8.5 fat five rims
11-08-2013, 03:19 PM
#48
no noticeable increase in braking.....did it cos i was tired of servicing the calipers....and i had one bad rotor...so i decided to swap out every thing and keep the 13wg calipers and rotors as spare
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
11-08-2013, 04:09 PM
#49
Real Name: Boogie
Real Name: Boogie
I've read somewhere that the Sport Editions have a bigger brake set up. Would this Tundra set up happen to be the same?
'03 V8 Sport Edition. 2013 FJ's Front/Rear, 5100's @ 1.75, SCS Stealth 6 Matte Gunmetal, 265/70 17 Nitto Terra Grapplers
11-08-2013, 06:21 PM
#50
Real Name: Alex
Real Name: Alex
Don't drilled rotors crack easier, though?
11-08-2013, 06:58 PM
#51
Real Name: George
Real Name: George
Yes they do. I didnt use drilled rotors I used stock sport edition rotors and wh calipers. My limited had the smaller stuff on it from factory
11-08-2013, 07:15 PM
#52
Real Name: Alex
Real Name: Alex
OH, so you just upsized? I guess OP went with drilled.
07-22-2014, 09:36 AM
#53
Originally Posted by Ducmonsta
After trimming the backing plate and painting, this is what you'll end up with.
Attachment 83047
I just completed this yesterday. Great write up! I did not paint the backing plate though. Think that will be an issue? I didn't because it would be very tough to cover the entire plate without overspraying the nearby components. I did clean it with brake cleaning fluid.
2004 SR5 V8 4WD White - Full LED Swap - Pioneer BT Stereo - Lite Racing UCAs - Toytec Bilstein 5100 Front 3"
Superflex Rear 2"- Spidertrax 1.5" - 255/75r17 Destination AT - SS Brake Lines - Prothane Bushings - SE Brake Upgrade - Full Synthetic
1994 SR5 V6 4WD Black - Bilstein HDs - OME 900 - 31" Destination AT
07-22-2014, 11:25 AM
#54
Real Name: Michael Mayfarth
did it by accident...
So, I inadvertently did this upgrade. I have a 2003 limited v8 and assumed that with the 17 inch wheels I would have the bigger brakes. NOPE! so we already had the bigger rotors and the bigger calipers, plus the smaller rotors and calipers were not in stock and cost more... So, my dad and I just decided to give it a go. We did not have to modify the backing plate, just pushed and bent it back a bit.
I dont notice any difference in the stopping distance like I did when I did the WJ brake upgrade on my jeep. That was going from single side single piston, brake calipers to 4 piston brake calipers... big difference...
All in all this is one of the easiest "upgrades" that I have done so far...
2003 Limited V8
NW Trail Innovations Bumpers,Bilstein 5100's, OME 886, Dobinsons 701 Rear Coils, Camburg UCAs, 315/70/17 Duratracs, Maltby Fab Roof Rack
07-22-2014, 11:30 AM
#55
Originally Posted by WXman
I'm considering ordering parts to do this mod, but the bare minimum is $300 to do this, and quite a bit more if you use higher-end parts.
So I'd like to hear from people who have done it, did you instantly notice a large difference in braking? Or was it a subtle difference that was kind of hard to tell?
Use Rockauto.com if you are able to wait. I spent just under 200 for calipers and rotors at Oreilly's. I already had new pads, just stuck calipers...
No noticeable difference, just do it because the parts are cheaper and available...
2003 Limited V8
09-26-2014, 09:34 PM
#56
For the guys who have done this upgrade: are you experiencing less sticking calipers with this setup? I'm getting tired of doing a brake job on this thing (what seems like) every summer....
I'm not overly concerned with better performance (not that I'm against it) but I'd really like a set of calipers that are less prone to seizing up.
2003 4Runner SR5
Black 4.7 wife's DD/family hauler
2008 Unlimited Rubicon
my DD/weekend warrior
09-27-2014, 05:06 AM
#57
Not really, they seem to be just as prone to sticking because the calipers are the exact same design, the only difference is the mounting points are extended a bit.
2006 Limited V8 4x4 - His
2007 SR5 V6 4x4 - Hers
09-30-2014, 10:27 PM
#58
poop. that's what I figured...thanks.
2003 4Runner SR5
07-03-2017, 06:30 PM
#59
So I've got a 2008 Limited; this wouldn't be an upgrade for me? But the 5th gen is a mild (rotor) upgrade?
05-30-2018, 09:18 AM
#60
I know this is a very old thread, but I need to add some information.
The difference between the two rotors is significant.
Surface area of 319mm standard rotors = 123.8 sq inches
Surface area of 338mm sport rotors = 139.1 sq inches
This is a difference of 15.2 sq inches, which is a 12.3% increase in swept braking area. Also there is greater mass (larger heat sink) which decreases brake fade. Heat is the number one enemy of brake efficiency. Larger rotors will provide lower peak temperatures and longer wear cycles between brake pad changes (lower maintenance costs), as well as significantly better braking ability during times of frequent hard braking - mountain roads, etc.
The Sport brake upgrade is definitely worth doing.
2006 T4R Sport XPS, V8, 4wd
- OME 886/896 coils, JBA Upper Control Arms, Bilstein 5100s, Bluetooth, TPMS bypass, Satoshi Grill, Yaesu FT7900 HAM Radio, etc.
